It is currently Sat May 25, 2013 4:22 pm
 Post subject: HELP!! What is the best product for cooling a RAM?
PostPosted: Fri Aug 19, 2011 3:18 am
Hey guys, I’ve got a problem with using my RAM … I used the thermal tape to attach my heatsink on it yet it’s still very hot. Sigh … seems like my cooler doesn’t cool down the RAM properly. My card was almost ruined when I tried to remove the heatsink. Please help !!! Is there something like a thermal pad that can resolve this problem?
 Post subject: Re: HELP!! What is the best product for cooling a RAM?
PostPosted: Fri Aug 19, 2011 8:12 am
What brand of ram?
PostPosted: Mon Aug 22, 2011 6:01 pm
Sorry for the misunderstanding! I mean the RAM on my VGA card - AMD HD 6970 with a non-stock cooler
PostPosted: Tue Aug 23, 2011 6:05 pm
ARTIC G-1 is a thermal glue that has higher heat dissipation rates than thermal pad and easier removal than thermal tape. Check out [Youtube]http://www.youtube.com/watch?v=OZaef91JiIw&feature=youtube_gdata [/Youtube]
Hope that helps.
PostPosted: Mon Sep 05, 2011 7:29 pm
It's not glue until you cook it. If you are cooking it, there is something wrong.
PostPosted: Fri Sep 09, 2011 12:28 pm
I'm sorry, but how do you know that your VRAM is running too hot? When you installed the aftermarket cooler, were you provided with new pads, or did you attempt to re-use those from the stock cooler?
