It is currently Sun Jan 25, 2015 2:36 am
 Post subject: Lookin for OC advice Nforce 750I Core 2 Duo E6750
PostPosted: Mon Jul 25, 2011 6:29 pm
I have never Overclocked have done abit of research, got Prime 95, CPU Z, Orthos, HW Monitor, and am usin Hyper Pi for quick benchmarks. Still haven't run base stress test with either Orthos or Prime 95. I've already set the jumper, and base running temps are 31c-34c. I'm hoping for some tips or previous exp with any settings from users here. just want to know what is safe for me to do. I don't want to touch Voltage much
So here is my System.
Mobo XFX nforce 750i MB-750I-72P9
GPU PNY Nvidia GeForce GTX 550Ti 1024MB GDDR5
Name Intel Core 2 Duo E6750
Codename Conroe
Specification Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.F.B
Core Stepping G0
Technology 65 nm
Core Speed 2666.6 MHz
Multiplier x FSB 8.0 x 333.3 MHz
Rated Bus speed 1333.3 MHz
Stock frequency 2666 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4096 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 8.0x
Max VID 1.350 V
Memory Kingston hyper x Dual Channel 333.3 MHz 5-5-5-15-20-2T
PSU 500W Raidmax
 Post subject: Re: Lookin for OC advice Nforce 750I Core 2 Duo E6750
PostPosted: Mon Jul 25, 2011 8:47 pm
Attached are my CPUZ Screens (nvm cant uplaod attachments)
PostPosted: Thu Jul 28, 2011 7:10 pm
Million Club - 10 Plus
http://www.newegg.com/Product/Product.a ... 6819115070
That should get you started with better performance. :)
PostPosted: Fri Jul 29, 2011 4:15 pm
Million Club - 20 Plus
what CPU cooler are you using?
PostPosted: Fri Oct 14, 2011 8:11 am
Stock fan
PostPosted: Fri Oct 14, 2011 8:12 am
Oh and gray i bet it would if i had 300+ dollars to blow on it....
PostPosted: Fri Oct 14, 2011 8:19 am
this is my validated CPU Z
http://valid.canardpc.com/show_oc.php?id=2045985
