Overclocking is never an exact science. Two systems with identical hardware may vary considerably in their potential to reach high speeds. You've chosen quality hardware for your build. I myself run a Corsair H50 in a mini-itx rig. With an i7 860S OC'ed to 3.8Ghz I hit high 60's, so for a closed loop liquid cooler they're not bad. The general rule of thumb when overclocking is to start modestly, monitor temps and stability, and increase gradually. If the system should at some point become unstable, adjust the memory divisor to lower the RAM speed, or if the BIOS supports it, run the RAM unlinked from the BCLOCK altogether. If the CPU is still running cool when you reach instability you can always opt to bump the voltage a bit. Grab yourself a free tool like HWMonitor to record temps and push the system as long as you are comfortable with the results. Sooner or later you'll find the happy medium between performance, stability, and temp.
