It is currently Tue Jun 18, 2013 7:23 pm
 Post subject: So Is This A Good Reading
PostPosted: Wed Jan 05, 2011 1:00 am
So i got the H50 instead of the H70 and ran a push pull config on it. Then i OCed my 955 BE to 3.8GHz and have ran Prime95 for almost an hour and this is what i have. My idle is between 27C & 31C
Link for Larger Image: http://img716.imageshack.us/img716/8379/stresstestv.png
My question is is this a good reading. Thanks
 Post subject: Re: So Is This A Good Reading
PostPosted: Wed Jan 05, 2011 4:36 am
You are doing better then me right now :)
I only have one fan on my H50 at the moment though. I should drop down to 3.8 Ghz and see what I get for comparison? I need to get some high flow fans on order though. I don't think what I have is fast enough to do the job. I want to keep this thing running 4Ghz if at all possible, but 3.8 Ghz isn't bad either (still a 1 Ghz improvement).
PostPosted: Fri Jan 07, 2011 3:31 pm
You're 20C cooler than my i7-920 C-Step at 4.0GHz.
I'd be VERY excited about those temperatures if I were you.
You find some good fans for the H50 CrashTECH, let me know bro. Think I may need to put an order in myself...
