It is currently Fri May 24, 2013 4:50 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Phenom II X4 965BE
PostPosted: Fri Aug 13, 2010 11:18 pm
Spartacus wrote:
That cooler is excellent, but you have to have good case ventilation.
Often one of the most overlooked, and easiest things to improve in air cooled systems.
Air's biggest downfall for cooling, is it's extremely low thermal capacity (how much heat energy is required to raise the temperature of the mass absorbing the heat). The two main that contributes to air's ability to cool well, is the volume of air absorbing that heat. One other factor that plays into this, is the difference in temperature between the sink and the air. A greater difference between the two means that the air can absorb more energy before temperatures equalize, as well as heat transfer happening more rapidly when there is a greater temperature difference. Both the volume of air absorbing the heat, and the temperature difference between the heatsink and air are enhanced greatly by good case ventilation.
PostPosted: Thu Aug 19, 2010 12:46 pm
So now I have my 965 sittin at 3.7 Ghz. Running Prime95 as well as Google Chrome, been going for an hour now hit only 60C @ 100%. Seems like my ICD7 finally set in.
