It is currently Tue Apr 21, 2015 1:59 pm
 Post subject: Antec 300 Fan Controller ideas?
PostPosted: Fri Nov 06, 2009 7:35 pm
I've been working on cleaning up my cabling. First, I cut some holes in my mobo tray (one top left and one bottom right) to route cables behind. Now I have the 3 speed fan controller switch's that come on the fans in the case just hanging inside. I'm not sure what to do with them so I've made sure they are all at least easy to access by only opening one side of the case but I want to go a little further. I thought maybe you guys could help me out here...
PostPosted: Fri Nov 06, 2009 8:41 pm
Million Club 2+ [PC]*
In my Antec 900, I used small, black zip ties to zip tie those switch dongles to one of the inside mounting holes on the body of the fan itself.
As far as a fan controller, this one has lasted for over two years now with nary a hiccup ***knock on wood*** and it controls four of my fans via variable speed knobs and two others via three position switches. +12V/Off/+5V. I've never had a fan controller last as long as this one has. I've tried the blingy ones with LCD screens and all that jazz and eventually, they either short out, the LCD goes out or, in the case of two others, the damned hi-temp warning buzzers wouldn't stop sounding. With the Zalman controller, I just set all the fan speeds to "Hi" via their switches and then control them from the controller.
The only drawback I've had with it are how bright the blue LED's are on front. But a little black tape wrapped around them and cut 'just so' took care of that.
