It is currently Sun Mar 29, 2015 12:07 am
 Post subject: turn an ATX case into a micro ATX case ( i'm new at this)
PostPosted: Sat Oct 24, 2009 10:00 pm
I hope this is the right place for this post.
I have an ATX Mid Tower Computer Case:
http://www.newegg.com/Product/Product.a ... -_-Product
[/url]
But it is only ATX compatible, unlike a very similar case:
[url]
which can have either or. I'm wondering if it would be easy to modify my case to be able to handle a micro ATX???
thanks[/url]
PostPosted: Sun Oct 25, 2009 2:51 am
Million Club - 5 Plus
mATX is backwards compatible with ATX.
mATX will fit in any ATX case.. its designed that way.
EDIT: 1st case even states that, you missed it:
Quote:
With its innovative styling and high quality construction, the Cooler Master Centurion 5 CAC-T05-WW case lends a hot, edgy look to your system. Measuring in at 120mm and 80mm respectively, the front and back fans on this case will make quick work of noxious dust and heat that can potentially wreak havoc on your PC.
This stunning case, compatible with all ATX and Micro ATX motherboards,
PostPosted: Sun Oct 25, 2009 7:17 am
well there you go, haha, it looks like I just need to be a better reader oops
thanks though :)
PostPosted: Sun Oct 25, 2009 9:16 am
no worries; its happened to most everyone here at some point :wink:
