It is currently Thu Jan 29, 2015 10:34 pm
 Post subject: Modding a PSU.
PostPosted: Thu Oct 15, 2009 5:15 am
I just bought a new BFG 260 GTX which requires two 6 pin power connections. My 500w PSU only has one 6 pin connector.
The good news is that I have an adapter that takes two 4 pin molex jacks and turns them into a 6 pin jack. The bad news is the only free 4 pin jacks I have comes from the floppy drive which is the wrong size jack (but the same voltage) and a SATA drive jack (again same voltage).
So for a temporary measure I took two 4 pin molex jacks from a dead PSU and replaced the above two jacks so that I could use the adapter.
So far I've been using this setup for about a week and have had no problems. I even played Crysis on Very High settings without a hickup.
Do you think I will run into any problems if I continue to use this setup or should I get a PSU that has the proper connections?
PostPosted: Thu Oct 15, 2009 5:28 am
Million Club [PC]
Million Club [PC]
I've replaced connectors on the PSU with other ones twice, as well as adding new connectors to a PSU once. One ran just fine for five years until I retired it, one was killed by a lightning strike, and one is running just fine now. So long as you get the wire placement correct, you should be just fine. :wink:
PostPosted: Thu Oct 15, 2009 6:05 am
If it works fine now i see no reason why it would conk out later on.
PostPosted: Thu Oct 15, 2009 6:17 am
Million Club - 5 Plus
there should be no problem.
did you solder the new connectors in? provides a better connection than just twist on wire nuts or "twist and tape."
PostPosted: Thu Oct 15, 2009 6:28 am
Right now the wires are just twisted together and taped.
I was planning on soldering them once the initial testing phase is over.
My main concern is whether having two drives and a video card on one set of leads would be too much drain.
PostPosted: Thu Oct 15, 2009 6:37 am
Million Club [PC]
Million Club [PC]
drives don't pull very much power. I think you'll be just fine, just sauter them.
PostPosted: Thu Oct 15, 2009 8:17 am
You are probably fine. I have done this several times. If you were close to maxing your PSU... then it would be an issue.
DO make sure you solder and heat shrink though. Shorting your PSU would be all kinds of bad.
PostPosted: Thu Oct 15, 2009 8:38 am
Thanks guys.
My wallet thanks you too. ;)
PostPosted: Mon Oct 19, 2009 4:27 pm
TravBv2.0
TravBv2.0
Not to be a douche, but I couldn't leave this one alone.
It's actually spelled "solder".
Sorry buddy, but I had to. :lol: :lol:
PostPosted: Mon Oct 19, 2009 5:30 pm
Million Club [PC]
Million Club [PC]
oh yeah fail lol. Make sure to lightly fry your connections. :lol:
