It is currently Tue May 21, 2013 4:57 pm
 Post subject: Check out my legacy gateway..Tell me what you think..
PostPosted: Fri Jan 14, 2005 9:15 am
Its a nine Year Old Pentium 133 gateway case (this is a bigboy) I painted the exterior and interior silver. Also removed outer shell and cut plexi glass sides for easy no screw sliding door access.
Asus A7n8x Rev 2.0
120gb western digital parallel 8mb cache drive
Amd Barton 2500 ocd to 2.285ghz
Coolermaster Aero 7+ Cooler.
MGE/XD vigor 500watt power supply
ATI all in wonder 9600xt
Corsair platinum 512mb single channel
Coolermaster Cooldrive 4
Soundblaster audigy
Various lights
Future plans swaping the DVD rom for a DVD-RW
another 512mb stick of Corsair Ram
http://pictures.sprintpcs.com/guest/view/picture.do;jsessionid=aa4j8OcKilr4?lsdb=7&invite=LEMmYRmyPzz1Da28hLaU&subretailerid=SPRINTPCS&shareName=Photo&retailerid=SPRINTPCS
http://pictures.sprintpcs.com/share.jsp?invite=gEEmY8mZPz8MRk1U08bL&shareName=Photo
PostPosted: Fri Jan 14, 2005 9:45 am
I'd rather be modding!
The Gateway battle crusier case.
Folks might need a pic of the front with a yard stick or somerthing for scale to understand how big it is.
Oh yeah - wrap those links with BB code or the Mods will have a hissy.
like edit them with
"[url=http://enter_url_here]Text - Pic of my case[/url]"
That will stop them from breaking the frames.
Manta
PostPosted: Fri Jan 14, 2005 9:50 am
thanks will do... Yeah the front looks great with the cooldrive.. the case stands bought 3feet to 3 1/2 feet tall.. its a big mofo.. my friends cant believe i resurrected it. i mainly use it for the TV function recording and what not.. plus halflife 2 looks awesome on the big screen..
PostPosted: Fri Jan 14, 2005 12:41 pm
I have that case sitting in my basement. there is sooooo much room in that case. You need a little wire management thugh, which aint that hard in that case. thats a perfect case to mod a watercooling kit into the top, seeing as there is room for two PSUs and the normal one sits lower than the top. you could fit the radiator right above/on top of the PSU and have fans blow out the back with a little modding. I'ma start working on one. I'm already working on 2 projects, why do I need another one?
PostPosted: Fri Jan 14, 2005 2:10 pm
yeah i've been thinking on water cooling for a long time now.. i've been working on the wire managment as well i took those pics when i put in the cooldrive and the power supply so i had a lot of cables to run in a short amount of time. I'll take better pics tonite and show you guys.. But thanx again for the input i appreciate it. the one thing that stinks though is that the case normally has a cross bar in the middle for support. i removed the bar cause it was just an eye sore. Im gonna have to reinforce the corners now...
PostPosted: Fri Jan 14, 2005 2:15 pm
That case is badass, I have a thing for old mothers like that. Been trying to find something huge like that, but they're mostly gone :cry:
PostPosted: Fri Jan 14, 2005 2:17 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
I could make a pc in the net tower i showd u a while ago. I'd have like 20 drive bays :shock: I cant figure out howda use that thing on my network.
PostPosted: Fri Jan 14, 2005 2:22 pm
my cousin may have another if you send me your email address i'll get in touch with you. :P
PostPosted: Fri Jan 14, 2005 2:41 pm
There, I changed the settings so you can add me to MSN or email me, don't know why I didn't have it like that in the first place.... :?
PostPosted: Mon Jan 17, 2005 5:38 am
ok guys i got some better pics..cable management is getting better. i have to pick up some zip ties...probably head to staples tonite.. Couldnt find a yard stick so i placed a large poland spring bottle next to it so everybody can understand how big this guy is.
MY COMP PICS REVISED
http://pictures.sprintpcs.com/guest/view/thumbnails.do;jsessionid=a8LDuLQtK-sa?invite=hE2mYtY5YzkAUhsza8hx
PostPosted: Mon Jan 17, 2005 10:44 pm
I think I need to make my Linux box mod outa the Gateway case I have lying downstairs. Thanks for the idea. I need to work on all my projects, I've been slippin, going to too many LAN parties and strip joints. ;)
PostPosted: Tue Jan 18, 2005 6:36 am
If your not doing anything with that case willah is looking for one.. just cant seem to find another. went to my cousin's and he only had the smaller version of the same case....oh well i guess i tried...
PostPosted: Tue Jan 18, 2005 6:38 am
ohh and does anybody know where i can buy the window applique that looks like the atom/alien fan grille i have in that case..much appreciated...I've just about looked everywhere...I know i saw it some time ago..
