It is currently Tue Mar 03, 2015 5:09 am
 Post subject: Skulls?
PostPosted: Sat Aug 08, 2009 8:03 pm
I'm looking at starting a case mod themed on Warhammer 40K. I haven't started or decided yet, but it is going to be between the Ultramarines, or the Pre-heresy Death Guard.
The Ultramarines are no problem. However part of the death Guards iconography is a skull within a spiked ring. I seen something similar on these boards. ( http://www.maximumpc.com/forums/viewtopic.php?t=9650 ) Biohazard
My question where did that skull come from, and how can I get one?
PostPosted: Mon Aug 10, 2009 9:48 am
not the adeptus mechnicus ( i think almost spelled that close ) games work shop realy doesnt seem to want their icons an art on aperail or a belt buckle would be perfect to ad to a case.
depending on size id look at http://www.shopanatomical.com/Skull_Models_Anatomical_Model_Anatomy_Model_s/32.htm
PostPosted: Wed Aug 19, 2009 6:06 pm
Thanks it's bit more than I'm willing to spend though, so I thought I'll just hold out for Halloween and check the Halloween stores. Then...
Well I'm going with a Black Templars theme.
