It is currently Mon Apr 27, 2015 5:16 pm
 Post subject: Tideying my EL-DIABLO up :)
PostPosted: Fri Jul 24, 2009 1:43 pm
So i have the ABS el diablo case,yes i no that alot of you don't like the flashy type case but i got it a few years ago when i was all into that shit lol.
I just ordered 3X 120mm yate loon red led fans to go with my current 3 120mm fans 360mm fan and 240mm fan,i also got a load of white cable braid so i will be braiding all my cables and myby even my 24pin
:wink:
But first i will be striping the inside and painting it gloss black and cutting holes for cables.
Here are some pics from haw it looks now (i swapped the 4870 for a GTX285)
sorry for the crappy pics of a 5mp sammy onmia cellphone :roll:
anyway will update as soon as my shipment arrives :wink:
PostPosted: Fri Jul 24, 2009 2:21 pm
4870 to a 285? That must have been sweet.
PostPosted: Fri Jul 24, 2009 3:41 pm
Yeah was a nice upgrade plus it looks alot nicer in my stupid big case lol
PostPosted: Sun Jul 26, 2009 10:13 pm
Why did you move your hard drives out of the case? It seems weird to have that much space and no drives installed.
PostPosted: Mon Jul 27, 2009 4:09 am
I think he was trying to gain more airflow.
PostPosted: Mon Jul 27, 2009 4:35 am
Im planing on adding a 120 rad and a res in the location of the hdd cage.
PostPosted: Sat Aug 01, 2009 9:06 am
Million Club [PC]
Million Club [PC]
a rad on an intake? You might have NB and SB heat issues though.
PostPosted: Sat Aug 15, 2009 2:39 am
It should not be a problem since i have a hiden 120mm fan blowing in from the front up top in the dvd drive bay.
And i have since added 3 new fans should be updating with some pics soon.
PostPosted: Sat Aug 15, 2009 4:47 am
Here is a small update and some pics of my other rigs,(i have braided all my cables now and added new fans but have yet to take pics)
and some pics of my new setup:
and my other gaming room:
PostPosted: Sat Aug 15, 2009 1:53 pm
Monkey Fed [PC]
Monkey Fed [PC]
HA! You use the same theme for FF that I do! Aero Fox, right?
PostPosted: Sat Aug 15, 2009 1:57 pm
Yeah LOL been using that theme for so long now its still my favorite :P
