It is currently Thu Mar 26, 2015 9:20 pm
 Post subject: project big red
PostPosted: Fri Jul 03, 2009 11:54 am
To start no, its not the gum..... but it is, or was a coolermaster centurion 5. this is a worklog in progress, comments and suggestions are welcome :D
started off as this:
What i just did is replaced the clear side panel window with a red tinted one
PostPosted: Sat Jul 04, 2009 5:25 am
I would strip the case and repaint the inside black for a start,next i would cut holes in the mobo try for cable management.
And if you handy with a dremel i would cut a hole in the bottom for a fan and 2 holes on the top for fans.
PostPosted: Sat Jul 04, 2009 6:00 am
im going to be doing some cable management so scratch that, and i really dont see stripping the system viable, at least not on this build.
PostPosted: Sat Jul 04, 2009 6:01 am
Doing any real mods with all the components in it will be rather hard.
