It is currently Mon Jan 26, 2015 7:27 am
 Post subject: mirrors?
PostPosted: Fri Jun 12, 2009 9:21 am
has any one try to chrome the entire inside of there pc and install alot of lights, so it would look super bright, i might do it and change my side pannel into a 2 way mirror were you can look inside with all the light bouncing around and hardware reflecting left and right, it a cheap mod but i think it would look pretty sweet what do you think?
PostPosted: Fri Jun 12, 2009 10:01 am
Team Member Top 1000
It could work, never thought of a two way mirror.
Legit chroming, on the other hand, as in plating the inside of a case is by far NOT CHEAP by any imagination. The dream machine from 08, which had a bunch of chrome on the outside, cost about $5000 to do.
http://dl.maximumpc.com/Archives/MPC0908-web.pdf
Unless you know of a really cheap way to do it, it wouldn't be a easy mod with legit chrome
AJ
 Post subject: ummm i think i can chrome it for under 15 bucks
PostPosted: Fri Jun 12, 2009 10:14 am
AJ
im not doing a profesional grade job just buying chrome spray paint and spraying it, then cutting and buying the 2 way mirror is going to be a pain.
heres the chrome spray i might use, maybe something nicer.
http://www.amainhobbies.com/product_inf ... aint-3.5oz
PostPosted: Fri Jun 12, 2009 10:19 am
I'm thinking mirrors or chrome finish might also reflect heat from your components around the case as well..
PostPosted: Fri Jun 12, 2009 12:04 pm
Million Club [PC]
Million Club [PC]
I don't think that would be a very big deal if you just maintain airflow. chrome really only reflects radiated heat, which should get immediately whisked away as hot air once it leaves the heatsink.
PostPosted: Fri Jun 12, 2009 1:44 pm
Team Creamsicles
Team Creamsicles
I think it would be pretty cool if you chromed the inside, and mounted some lasers and a smoke machine in it, so you can see the laser beams bouncing around on the inside.
 Post subject: haf 932
PostPosted: Fri Jun 12, 2009 7:45 pm
im using a haf 932 so i high doubt its going to be a cooling problem if i does get bad ill use liquid cooling.
PostPosted: Tue Jun 16, 2009 11:43 am
Team Member Top 250
Team Member Top 250
use a ghetto mirror
Tinfoil and glass.
http://www.make-stuff.com/formulas/mirrors.html
