It is currently Tue Apr 28, 2015 7:14 am
 Post subject: My mod from back in the day
PostPosted: Mon Jun 08, 2009 12:46 pm
I never did post some case mod pictures I did with a Cicero from Future Shop (my first computer before I knew how to build them), so I thought I would post them to see what you guys think. I put plexi in the side and added a neon light at the bottom as well as a fan grill (then changed the fan grill to another aha). Unfortunately the case is long gone (sold to a friend), but I wanted to show you guys anyways. I was quite proud of it.
PostPosted: Sun Jun 21, 2009 6:31 pm
looks nice. nothing to crazy. just the way i like it.
PostPosted: Mon Jun 22, 2009 2:27 am
Team Creamsicles
Team Creamsicles
Nice job.
PostPosted: Mon Jun 22, 2009 4:55 am
Thanks guys :D
PostPosted: Tue Jun 23, 2009 8:06 pm
Thats a good looking PC!! i Like the neon, i want to do that to mine
PostPosted: Wed Jun 24, 2009 3:37 am
Thank you! You totally can, just get some plexi and find a way to mount it where your side panal would be. Your going to need tools to cut it though, I used a drill press to make the holes and a table saw to cut the plexi to size. You can buy neon lights online (I forget where I got mine though) and I got the good fan grill at a local computer store.
