It is currently Fri Apr 24, 2015 6:45 pm
 Post subject: CRT Radiation and Motherboard
PostPosted: Sun May 10, 2009 12:07 pm
I'm bored this weekend, so I decided to take on a project. I decided to make my own All-in-one with some spare parts. I want to hang a mini-atx motherboard on the back of an old 15' CRT monitor and put a power supply and hard drive somewhere else on the monitor. Would I run into problems with static emissions from the monitor screwing up the motherboard, power supply, or hard drive?
PostPosted: Sun May 10, 2009 3:14 pm
Team Member [Top 500]*
No there won't be a problem but there are few things to avoid like the single wire attached to the side of the CRT. If you just want to extend off the back of the CRT case (enclosure) there should not be a problem.
Ron
PostPosted: Sun May 10, 2009 6:27 pm
Thanks! I got everything working and there is no problem!
PostPosted: Mon May 18, 2009 12:40 pm
Post some pics!
PostPosted: Tue May 19, 2009 8:29 pm
lets see them :lol:
