It is currently Thu Mar 26, 2015 3:07 pm
PostPosted: Fri May 08, 2009 7:24 pm
Anyone have suggestions or pictures of the wiring inside a cooler master cosmos?
PostPosted: Sat May 09, 2009 9:09 am
Team Member Top 1000
I happen to own one and the wiring I must say is a bitch. The case was designed with ease of use in mind and not much attention was paid to cable management. Its only saving grace in that department is that there are no case windows.
I've found that routing unused and if it will reach, used power supply cables through the bottom slot around to the backside of the hard drive cages and stuffing them in there works well. You have to be careful how many you stuff through and how because if its too thick the side panel won't latch. The rest is all about shortening to length.
Like the power cables for my GTX 285 are mostly kept in the bottom of the case near the power supply and I zip tied the rest so it would only just reach.
Hope this helps.
PostPosted: Sat May 09, 2009 9:45 pm
Sounds like an idea. I'll try it out. Hope i can get it a little bit neater.
