It is currently Wed May 06, 2015 1:51 am
 Post subject: Building my own case
PostPosted: Mon Mar 30, 2009 3:10 pm
OK, so I am attempting to build my own case. I have made most of the outer shell of it on AutoDesk Inventor, but I am asking for suggestions on actualy building it. If there is anyone who has built a case from scratch, I would love to hear from you. Right now, I have two big questions in my mind:
1. How can I work the power button?
2.What material should I use? I have the resources of a full tech room at my service, but as far as I know, most metal cutting is out (I can do small pieces, but thats about it.
PostPosted: Mon Mar 30, 2009 4:15 pm
Do you know how to make things? You're asking about power buttons, and we have no idea if you can make a hole for a fan.
Very vague, so I say...learn your way around a toolbox, and start buying crap you don't have.
You can make a panel for a case without a shear? It'll be square and not looking like you duct taped it together? You've got drills, taps, and a guide to tell you what drill to use for so-and-so tap?
Basically, you've attempted something more basic than this before attempting to confront an ATX standard?
PostPosted: Tue Mar 31, 2009 6:29 pm
it would be best if you have a set of calipers and an existing case that you can take parts and measurements from for your new case. I'm also currently working in a computer case in inventor but I'm not planning on making one from scratch.
PostPosted: Wed Apr 01, 2009 9:30 am
That's a great idea...never thought about that I guess. Transferring specs over would be the way to go. With a 6" rule and a set of calipers, it'd be a cinch to mock up a case.
Don't forget to mix it up a bit though. If everything is transferred over, you end up with a duplicate ;) What's going to change, be modified, or customized to your build?
PostPosted: Wed Apr 01, 2009 9:33 am
Monkey Fed [PC]
Monkey Fed [PC]
Actually, it might be best to duplicate a case first to get a feel for how things work, fit together, etc. Then, take that case you just built, and start making changes. That's kind of how I roll with a lot of fab stuff.
PostPosted: Wed Apr 01, 2009 10:41 am
I meant to just transfer things like mobo standoffs or the width of expansion cards.
PostPosted: Wed Apr 01, 2009 12:15 pm
I/O rectangle, the distance to the first PCI slot as well...that's really all I'd think a person would need, and then go from there.
Doing this on a big piece of butcher's paper could have you folding it around and making things work. Can you still buy that stuff!?
PostPosted: Thu Apr 02, 2009 7:15 am
This would count as butcher paper I would think
butcher paper
PostPosted: Fri Apr 03, 2009 12:53 pm
thats a great idea. next time that i get a use of inventor, i will bring some calipers
PostPosted: Fri Jul 10, 2009 8:44 pm
well as far as building the case goes i'd go with a nice thin gauge aluminum, you can pick it up from any home depot. i've built one from scratch and while it looked nice it was a less then pleasant experience and i know my way around this stuff my grandfather is a classic car fanatic and i've spent years in his garage shaping metal. make sure you get the tools you need a dremel isn't going to be enough no matter what they tell you. and add some bandages if your working with any kind of sheet metal an relatively inexperienced it's reasonable to expect that your going to cut yourself a few times it happens trust me.
PostPosted: Sat Jul 11, 2009 3:31 pm
lol, epic necro anyone?
