I love you Grump... <3....
Grump is prolly the most experienced modder i've ever seen. this is from another thread a litle below this one. take a look around the forums, you'll find a lot in the MRL and a lot of my ideas and inspiration come from the guys on this forum. I love these guys, and wouldnt give them up for anything. <3
xveganx, xveganx, xveganx,
I really hate to live up to my name, but jeez man, did you read the rules before you posted your first message -- 4 months ago? Did you happen to notice the size of your images before posting them? You have a 900X1200 and a 1200X900 that weigh in at a whopping 769 KB. I usually surf on a broadband connection, but the snow has left me with only my dialup and it took a couple of minutes to download your pictures.
Have a little consideration, willya?
Okay, that rant aside, I can see you tried to hide the wires and even wrap your flat IDE ribbons, but I guess you know it needs a little work. It's pretty difficult to get all the wires and cables in a system out of sight. They just don't build a case or give you enough wire length to do that. So, you have to plan a wire management system that makes it as unobtrusive and neat as possible.
You mentioned sleeving, but that's not an easy task for the novice. To do proper sleeving, you would have to remove and replace molexes and connectors, using special tools, or at the very least, special techniques. I've seen beautiful mods turn mediocre with a bad sleeve job alone.
An excellent way to give your wires and cables a neat and orderly look is to use split loom. It's inexpensive, easy to do and, with all the various sizes and colors, makes a bland interior look stylish and professionally done.
I can see you wanted to increase your airflow, as well as your neatness factor, by using rounded IDE cables. No doubt you experienced some difficulty with wrapping the HDD cables. Is that heat shrink? Notice how it kinked and that much of it didn't get covered? Well, you had the right idea.
Attention to the littlest details can make the job easier and look much better. If you can't afford to get the same style and color cables for all your drives, you can cover them all with split loom to make them look the same. The loom will also allow your cables to flow in smoother lines. I would suggest you invest in more silver braided IDE cables like the one on your optical drive. Get them long enough to route along the side of the drive cage and follow a single path to the connectors on the mobo. Measure for each cable so that you get the length that is best suited for the path you follow.
There are a lot of small wires -- fan connectors, front panel wires, etc. -- that all need to be planned out. Most of these are prob'ly long enough to tuck behind the edge of the motherboard, along the drive cage or the bottom of the case. You may have to try a couple different routings just to get the look and accessibility you need. Do keep in mind that these wires may have to be unplugged occasionally.
There are a few things that make wire management a little easier. Zip ties are great for grouping wires together and for attaching them to various points on your chassis to hold them in place and out of the way. You can also use them to snug the ends of your split loom so it doesn't slip and expose the ugly wires underneath. Like the split loom itself, zip ties come in a variety of colors, so you can mix and match for a very unique look.
Another item I have used with great success is that sticky, rubbery black stuff that auto glaziers use around your windshield. I don't know what it's called, but it comes in a coil with a silicone coated paper running the length of it. I pull off a little ball and stick it an out of the way place and press the wire into it. It stays put, but is easy to pull free without having to cut it loose like you would a zip tie.
There's also small wire clips and clamps in a variety of sizes you can get in the hardware section of almost any store. They have sticky pads with peel-off paper to make mounting them easy.
These are just a few things you can do to sweeten up the inside of your case. If you have a window mod and a few lights, it will make all the difference in the world if your wires and cables have that finished look. If you need links to where to buy any of the items I mentioned, or need additional suggestions, let me know. For now though, see about resizing those pics so we can all enjoy the progress of your wire management project.
Click any image to see a larger one.My Best R'gards, Grump
The Mad Modder
