It is currently Sun Apr 19, 2015 5:18 am
 Post subject: Easy mods that don't require a lot of space?
PostPosted: Sat Mar 28, 2009 10:56 am
Mr. Late Night
Mr. Late Night
Ever since I've built my PC a bit over a month ago I've been itching to personalize it a bit. The problem is that I don't have a workshop to do some of the really cool stuff that I'd like to do. Such is life in an apartment. I'm just curious if other folks that are in apartments have done mods that don't require much space to perform them in. Any ideas for things that I can do to personalize the case a bit? This is a Cooler Master RC-534+ for reference.
PostPosted: Sat Mar 28, 2009 1:09 pm
You dont need much room to paint, although if you have a balcony that would help otherwise good ventilation is a must. A dremel can be used in small spaces, hand tools and the like dont require alot of space either. In reality you can do anything in a relatively small space you just have to figure how to use the space you have effectively.
PostPosted: Sat Mar 28, 2009 1:24 pm
Million Club 2+ [PC]*
Since my case has the mobo out for RMA, I'm painting the inside of it and the drive cages. A balcony wouldn't be a good place to spray paint if your concerned about over-spray at all. :lol:
PostPosted: Sat May 09, 2009 3:12 pm
You could always change the LED colors! I belive that your case has a blue LED fan mounted in it. Change it out for a different color. Changing the power and HDD LEDs doesn't take any room at all, just a few basic tools every modder should have. You could also put a plexi window in it and etch it with a drimmel tool then light it up . The possibilities are only limited by your imagination.
 Post subject: another idea
PostPosted: Sat May 09, 2009 8:46 pm
check this out.
http://www.overclock.net/case-mods-gene ... n-mod.html
