It is currently Fri Feb 27, 2015 9:36 am
 Post subject: CoolerMaster V8 Cooler Mod
PostPosted: Thu Mar 05, 2009 8:45 pm
Ferrari 599 engine
Dissection of Coolermaster's new "V8" CPU Cooler
Model RR-UV8-XBU1-GP
CPU Socket Intel Socket LGA1366
Intel Socket LGA775
AMD Socket (Socket 940/AM2/AM2+)
CPU Support Intel: Core i7, Core 2 Extreme, Core 2 Quad, Core 2 Duo, Pentium Extreme Ed., Pentium Dual-Core, Pentium D, Pentium 4 Extreme Ed., Pentium 4 HT, Pentium 4, Celeron Dual-Core, Celeron D
AMD:Phenom, Athlon 64 X2, Athlon X2, Sempron
Fan Control PWM + VR Controller
Rated Voltage 12V
Start Voltage 7V
Operating Voltage 10.38V - 13.2V
Rated Current 0.12A
Input Power 1.44W
Dimension 120 x 128 x 161.1mm
Heat Sink Material Copper Base / Aluminum Fins / 8 Heat Pipes
Heat Pipes Dimensions 6mm
Fan Dimension (W / H / D) 120 x 120 x 25mm
Fan Speed 800 - 1800RPM
Fan Airflow 69.69CFM
Air pressure (mmH2O) 2.94mm H2O
Bearing Type Rifle Bearing
Fan Life Expectancy 40,000hrs
Fan Noise Level (dB-A) 17 - 21dBA
Fan Speed Adjustment Install on PCI Slot
Connector 4-pin
The Coolermaster's V8 logo was GONE IN 60 SECONDS!
The center portion was replaced Round Modders Mesh
1/8 thick acrylic riser
manifold air intake hose made from plastic wire loom, heated and bent
roughly 3/16" tall manifolds made from modeling clay
Next up, making 12, intake pipes! :D
My "worm chorus line" is starting to morph in to intake pipes. The next step is applying more clay to join them to the manifolds. From there, acrylic primer, then a coat of silver "manifold" colored paint, then off to mnpctech's master painter, Brad Galvin to have intricate details like the Ferrari text on the red covers painted.
The pipes will be smoothed over with another application of clay.
A little more sanding, and it's ready for paint details :thumb:
Hand painting the intakes has commenced. Using custom vinyl film stencil made on plotter for "Ferrari"
I wonder if Coolermaster would recognize it?
PostPosted: Fri Mar 06, 2009 5:00 am
:shock:
Wow!
PostPosted: Fri Mar 06, 2009 7:39 am
Monkey Fed [PC]
Monkey Fed [PC]
You know, this is a major coincidence. Last night, before I came on the forums, I saw a program that actually toured the factory in Italy where the 599 was made, and went through how they built these cars. Everything from the foundry where they make the castings for the motors, to the track where they test them before they get delivered to customers. I came here and saw this and promptly lol'd.
Nice mod, BTW. I think I just got some idea's for an after-my-wedding build.
PostPosted: Fri Mar 06, 2009 9:11 am
Damn, that's HOT.
PostPosted: Fri Mar 06, 2009 9:31 am
They will just remain ideas... I am slowly letting go of all of my dreams so that come this October, I don't have any to get crushed :) :lol: :P
PostPosted: Fri Mar 06, 2009 9:33 am
Monkey Fed [PC]
Monkey Fed [PC]
Man, I don't has to worry about that. She doesn't mind me buying stuff as long as I do it smart. I haven't built a new machine in ages anyway, so I'm due. I have yet to have her say no to anything, so long as we have the cash and it's presented properly. :twisted:
PostPosted: Fri Mar 06, 2009 9:47 am
Million Club - 5 Plus
that is sweet :)
nice job!
PostPosted: Fri Mar 06, 2009 10:23 am
Monkey Federation (Top 10)*
You never cease to amaze me do0d.
PostPosted: Fri Mar 06, 2009 2:29 pm
Team Creamsicles
Team Creamsicles
NICE!
PostPosted: Fri Mar 06, 2009 9:23 pm
I'm sorry, but I've just come to expect more from you guys. Honestly, this is the sloppiest mod I've seen you guys do. I really do expect better from you guys, considering all the stuff you've done before. This thing is majorly lacking.
PostPosted: Sat Mar 07, 2009 5:25 pm
That's because the wedding hasn't happened yet.
PostPosted: Sun Mar 08, 2009 4:22 pm
Thanks for all of the great comments guys!
The modified coolermaster "V8" manifold is finished.
PostPosted: Sun Mar 08, 2009 6:23 pm
What do you consider sloppy in this, it matches the engine extremely well.
PostPosted: Mon Mar 09, 2009 2:05 am
I dismantled Silverstone TJ07. We're painting it 2005 Ferrari F430 "Roso Corsa" Red
Removing the internal core
I love the single piece external construction.
I'm not doing anything to the removable MB tray, but wanted to post it anyway. These steel trays are by far the best I've ever seen used. Usually MB trays are flimsy aluminum.
PostPosted: Mon Mar 09, 2009 7:20 am
Cooler mod inspires full case mod? Good stuff!
PostPosted: Mon Mar 09, 2009 8:56 pm
Primarily the lack of fine sanding before painting, the actual painting itself, in other words, the lack of detail. We've all come to expect more from these guys, considering the ubermods they've done in the past. They're very talented people, and this, well, this is just sloppy and rushed. For Pete's sake, they just globbed silver paint on the "hoses" to represent clamps, and it looks horrible. I've painted model engines better, and I suck at it, mainly from lack of experience with them. Take your time, try to get as much detail out of it as you possibly can, and if you can't eak out any more, then you've done all you possibly can. This is not one of those cases, it's just a globby slop of paint on a once-beautiful heatsink cover. I sure hope the chassis is better.
PostPosted: Mon Mar 09, 2009 9:36 pm
I LOVE this! Absolutely beautiful. A job well done, sir! :D
PostPosted: Wed Mar 11, 2009 3:58 am
Thanks for the great feedback everybody.
Can you please tell if the HD version of the V8 cooler's video lags for you?
http://www.youtube.com/watch?v=pYmSkPhv3vQ
PostPosted: Wed Mar 11, 2009 6:07 am
Team Member Top 1000
Watched it. No lag whatsoever. Impressive intro - very well done. Great video of course.
AJ
PostPosted: Wed Mar 11, 2009 9:20 am
Wow, holy crap im impressed, how much to do mine!?
