It is currently Sat Apr 18, 2015 5:30 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Apr 12, 2009 3:25 pm
Easter brought a break this afternoon so I could get back to this project. I'm using a rotary tool with grinder attachment for excavating filler from the crevices of the bezel frame.
PostPosted: Tue Apr 14, 2009 5:45 pm
After more grinding today, I applied the 2nd layer of filler to areas of the bezel.
Pre fitting the plastic loom tubing
PostPosted: Tue Apr 14, 2009 6:58 pm
Team Creamsicles
Team Creamsicles
Wow this is a long process filling and sanding the foam.
PostPosted: Wed Apr 15, 2009 3:01 pm
Yes, it is long, but we're about there. Heres after sanding the 2nd application of Evercoat brand "Everglass: (short strand) fiberglass filler. I thought this would be the final coat, but I'm not satisified with the results yet. btw: I'm recording stages of the bezel for YouTube after getting several requests offlist. I'll remember to edit out all of the boring stuff..lol!
PostPosted: Fri Apr 17, 2009 1:38 pm
Test fit it tonight, touch up some details with spot filler, re-install the threaded rod and then I can apply the base coat to the bezel
PostPosted: Sat Apr 18, 2009 5:21 am
Test fitting the bezel onto the chassis and cut the wire loom tubing
PostPosted: Sun Apr 19, 2009 1:58 am
Very nice looking mod, very good work cant wate for the finish.
PostPosted: Sun Apr 19, 2009 1:38 pm
Thanks killer! I wired the 3x 120mm front intake fans, yippe!... I'd like the leds a tad dimmer tho
PostPosted: Thu Apr 23, 2009 9:18 am
I'm cutting a dead card to create the look of circuitry to the bezel's four protruding features. These will be painted flat black along with the bezel. I'll also be using model clay to add more details.
Shot of the workspace this morning, the cases are "Skully" for ongoing project series on [url="http://www.casemodblog.com"]casemodblog[/url], and black one is Matt's GOLIATH project in the corner which you'll see more of later. I'm fan of VWs too!
PostPosted: Sun Apr 26, 2009 2:39 pm
Applied Black Spot filler / sandable primer this afternoon. Nice change from Green. Gives you a better idea of how the final piece will look. It also helps reveal what areas of the filler I wanna keep touching up.
PostPosted: Mon Apr 27, 2009 1:38 pm
The bezel looks much better Black than Green.
PostPosted: Mon Apr 27, 2009 7:43 pm
Looks really good cant wait to see the rest of what you do with it. With the green leds in the fans, are you planning on lighting up the eye sockets on the skull? Hope to see more on it soon!
PostPosted: Tue Apr 28, 2009 6:22 am
:shock: :shock: :shock: Lookin' as hot as it is outside today! That flat black paint really did the trick!
PostPosted: Tue Apr 28, 2009 8:36 am
Thanks guys! planning white 3mm leds
Video update on YouTube
http://www.youtube.com/watch?v=PTIXbdU-rlQ
PostPosted: Wed Apr 29, 2009 9:37 am
Monkey Federation (Top 10)*
This case is turning scary sick man!
PostPosted: Fri May 08, 2009 8:42 am
Sorry for lack of updates, working on two other customized cases for clients. Need_for_Speed found this photo and sent it to me. It's the interior of a Turtle shell. It would be really cool to implement something like this somewhere into the build.
PostPosted: Thu May 14, 2009 5:35 am
How much you want for the finished case? :lol:
