It is currently Sat Apr 25, 2015 9:21 pm
 Post subject: LED Fans - Are there any where the LED can be turned off?
PostPosted: Fri Feb 06, 2009 1:47 pm
Hey guys, long time reader and first time poster. This site has been a great resource for me.
Quick question. I'm looking to build a new PC and I am interested in getting fans and perhaps a cpu fan with LEDs.
The problem is that I don't want the LEDs to be on all the time. Are there any case fans and/or cpu fans where you can turn the LED off without turning the fan off?
Will I have to custom mod that with my own switch? I can do that if necessary, but I would rather just pay a little extra for the fans and have it professionally done. Thanks a bunch!
PostPosted: Sat Feb 07, 2009 7:57 am
Team Member [Top 500]*
First welcome to the MPC Forums!
I don't know of any off the shelf LED fans that offer that option, not to say it doesn't exist just to say I am not aware of any. Your post did get me to thinking and I looked at an 80 mm fan I have lying here with LEDs in it. This one would be very easily modded. If you have the interest I could take some pictures and post them as to how I would go about it.
Ron
PostPosted: Sat Feb 07, 2009 8:01 am
That would be fantastic! Thanks!
I can get access to any basic equipment. I know how to solder as well, just not quite sure what the proper connections would be with those fans lol.
PostPosted: Sat Feb 07, 2009 8:04 am
Million Club - 5 Plus
we are probably on the same page here. on the ones Ive seen all you would need to do is cut a lead that goes to the ribbon cable the the LEDs are on and put a SPST switch on it?
not sure all LED fans use that method though.
PostPosted: Sat Feb 07, 2009 8:37 am
That was my take looking at the victim fan I had lying here. Everyday generic Antec labeled fan. The 3 wires fan connector line runs up a small channel to the fan motor. Lifting those wires out and out of the way reveals the pair that go to the foil. Just cut the red (+) and place a simple SPST switch in there and that would do it for a fan like this.
Ron
PostPosted: Sat Feb 07, 2009 10:06 am
Cool, thanks a bunch guys.
