It is currently Fri Mar 27, 2015 5:04 pm
Post new topic Reply to topic  [ 108 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Mar 02, 2009 8:04 am
I used Loctite again to secure the frame to the bezel I cut out. A little pressure is enough to ensure that it dries smoothly
I was about to add the PSU, but the screws I have are silver
So, I painted them to match
Once I get the system in, I'll be installing Vista Ultimate 64 bit
PostPosted: Sun Mar 08, 2009 5:49 pm
I haven't updated in a week or so, but I have been working on the front panel radio
And the LCD bay
PostPosted: Wed Mar 11, 2009 5:54 pm
So after a few days of thinking I'm not sure what I want to do with the front bays. I still have the frame, but I kind of like adding a media reader/fan controller instead
Here's with the fan controller. It's the same one I used with Project Namesake
And here's with the LCD frame
I've put in most of the components so far
Here's a look with the panel on, minus the video card
PostPosted: Sun Mar 15, 2009 10:17 am
The LCD display is garbage. When I turned on the computer it blinked and beeped again and again. Even the numbers were rubbish. Since I do like the idea of having a card reader and additional USB ports on the front panel I decided to gut it. I then merged the frame to the LCD cover
This is how it looks
While I wait for the silicon to dry I installed Vista Ultimate
PostPosted: Sun Mar 15, 2009 12:53 pm
Your wall is pretty awesome
PostPosted: Sun Mar 15, 2009 2:30 pm
Thanks!
PostPosted: Sat Mar 21, 2009 8:35 am
I need help. I'm almost done, but there's something bugging me. I can see some of the wiring through the window and want to cover it maybe?? The video card is just above so mesh might be good here, but it needs to look appropriate. I considered tacking the mesh to the inside of the window too, what do you think?
PostPosted: Sat Mar 21, 2009 9:08 am
just clean it up with some tie offs, or put an intake fan or fans there.
PostPosted: Sat Mar 21, 2009 11:01 am
Million Club - 5 Plus
I say get some split-loom wire cover. I've seen that under the hood of quite a few cars.
http://www.action-electronics.com/loom.htm
PostPosted: Sat Mar 21, 2009 11:02 am
Team Creamsicles
Team Creamsicles
yeah 2 small fans would work there. :)
PostPosted: Sat Mar 21, 2009 6:35 pm
team psycho or sumthin
Well, you just happen to be missing a `cuda grille:
http://www.moparpowerclub.com/steve_hs_1970_cuda.jpg
http://autorecreations.com/71CudaGrille.jpg
PostPosted: Wed Mar 25, 2009 8:24 pm
I decided to loom the wiring inside.
I think I'm done now
PostPosted: Sat Mar 28, 2009 4:25 pm
I am finished.
The final specs are:
Foxconn A74MX-K
AMD Phenom 9150e Quad Core
4GB DDR2-800 (2x 2GB)
ATI Radeon HD 4830 1GB
1x DVD-RW
1x Blu-Ray ROM
Here's his wallpaper
PostPosted: Sun Mar 29, 2009 5:21 am
damit nice man, i just would have went with a black or orange plastic tube sleeving thingy. i say videotape the reaction.
PostPosted: Sun Mar 29, 2009 7:14 am
Team Creamsicles
Team Creamsicles
Great mod man! I agree with Jacob though. The yellow loom doesn't really match. Black or orange would be better.
PostPosted: Sun Mar 29, 2009 8:49 am
It's been difficult looking for orange
PostPosted: Sun Mar 29, 2009 9:27 am
You are a god of modding. I want a vid of the reaction!
PostPosted: Sun Mar 29, 2009 9:37 am
Team Creamsicles
Team Creamsicles
What about paint? Or would it be difficult to paint it?
PostPosted: Sun Mar 29, 2009 9:35 pm
I painted loom before and it chips and peels very easy. I'd rather find orange loom and if I do before presentation day, I'll get it
PostPosted: Mon Mar 30, 2009 2:41 pm
Team Creamsicles
Team Creamsicles
Oh ok. They sell them here. Don't know how good they are though.
http://cableorganizer.com/wire-loom/colored.html#colors
