It is currently Thu Mar 26, 2015 11:43 pm
Post new topic Reply to topic  [ 108 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Feb 17, 2009 10:36 pm
Chumly wrote:
Wasn't the 'Cuda a factory outfitted Charger? I believe most would be radio delete, but if they had a radio it'd be the stock Charger AM radio.
It was based on the Dodge Challenger (at least '70-'74).
PostPosted: Tue Feb 17, 2009 11:01 pm
Challenger was a Charger first though...all the same. Just how you ordered the Charger. I'd commit a sin if I said they were all high option dusters...I mean, what's a road runner but a charger made challenger...with options.
PostPosted: Wed Feb 18, 2009 6:33 am
team psycho or sumthin
No, there is very little in common between the (Barra)'cuda and the Challenger(no sheetmetal is interchangable) but yes, the E-body is just a modified B-body.
A-Body(compacts): Dart, Valiant, Valiant-Baracuda(1964-67), Barracuda(1967-69), Demon, Valiant-Duster(1970 only), Duster, Lancer.
B-Body(Intermediate): 1962 Dart, Polara, Savoy, Belvedere, 330, 440, Satellite, Coronet, Charger, GTX, Road Runner, Fury, Cordoba, Monaco, Magnum, and the 1979 Chrysler 300.
C-Body(Full size): blah
E-Body: Challenger, (Barra)'cuda
F-Body(Compact after the death of the A-Body): Aspen, Volaré.
I know I'm forgetting a few.
PostPosted: Wed Feb 18, 2009 6:42 am
The auction page just said that it went to a Playmouth/Dodge of the same time
Next I cut out the headlights. Then I trace the holes on to the frame underneath
(I also decided to add a 2nd DVD drive)
After that I trace the holes on to the frame underneath
^^ I still have to paint the bottom of the case ^^
PostPosted: Wed Feb 18, 2009 3:10 pm
Team Creamsicles
Team Creamsicles
lookin good so far. I like the idea of using the Hood scoop as a blowhole/vent.
PostPosted: Wed Feb 18, 2009 7:12 pm
I wish I would've checked this out before he got so far into the build, It's awesome work but there are a few glaring mistakes...
Then I sit back and remember that it's just a PC case, he isn't restoring a `cuda, he isn't building a scale model of a `cuda, he is just building a case inspired by the almighty and most awesome `cuda.
PostPosted: Fri Feb 20, 2009 10:32 pm
I painted the bottom
And under the hood scoop
PostPosted: Mon Feb 23, 2009 10:01 am
After protecting the surface I decided on a good place to mount the hood pins
30mm seems like a good spot
The pins had to be cut way down because they had to go into the case without interferring with the DVD drives
Once I drilled out the holes, I added a single screw to each. These screws were once part of the radio and now are another touch of the real thing
And filled it with Loctite
And I added the pin. I'll let it dry overnight
PostPosted: Mon Feb 23, 2009 11:09 am
Loving the progress on this!!
Beautiful work!
PostPosted: Mon Feb 23, 2009 7:17 pm
Oh, I got my 130mm (not 120mm) exhaust fan in today
PostPosted: Tue Feb 24, 2009 1:54 pm
I'm thinking of mounting a small digital photo frame into the remaining 5.25 bays. I can connect it via internal USB and have it play a bunch of Cuda photos in a loop
PostPosted: Tue Feb 24, 2009 3:21 pm
Team Creamsicles
Team Creamsicles
That would be pretty epic.
PostPosted: Tue Feb 24, 2009 6:17 pm
Not to sidetrack, but if it's just sheetmetal, that doesn't make the car.
I was a chevy guy in a ford world with my first car, and there was a lot of difference with my '66 2+2 GT and a stocker coupe, let alone saying it was a Shelby. It wasn't just sheetmetal that changed and could be an option like the CA edition.
With the 'cuda, the lust was the Hemi. You can get that as an option in other cars and trucks. It's about the same as lusting for a 409 and thinking you can only get that in a '63 bubble window when that's not the case. Most that built 409's were truck blocks from smaller ci bases made into 409's to fit a class. Same with the Hemi.
Hell, anyone with a Ford Escort has a Hemi.
PostPosted: Tue Feb 24, 2009 6:35 pm
Monkey Fed [PC]
Monkey Fed [PC]
Or a Honda. Or a Toyota. Or a Ford V10. Or a new Silverado. :lol: Most of these new engines are Hemi.
PostPosted: Wed Feb 25, 2009 9:30 pm
I ran the cable through
And there's that
I decided to not use the temp gauge on the front and mount a small photo frame that will scroll through 200 or so Mopar images
It'll go right there
I'll need to construct a frame for it.
I'll cut it soon
PostPosted: Thu Feb 26, 2009 6:58 am
I cut out the panel
And here's how it's going to sit
I started the paint process
PostPosted: Fri Feb 27, 2009 9:46 am
Here's how the radio came to me
I cut out the mopar logo
And added a coat of flat black
And I remembered that my brother-in-law watches TV and movies on his aging laptop, so I removed one of the DVD drives and added a Blu-Ray ROM. The Radeon HD 4830 has a DVI to HDMI adapter so with the use of a quality monitor he can watch the latest and greatest in Hi-Def
PostPosted: Fri Feb 27, 2009 11:07 am
I've thought about this for a while and decided to start signing my mods. They are, in fact an art form, so it makes sense to sign them.
This is on the inside left panel
I mixed up some Loctite and smeared it on the Mopar logo
Then pressed it on the back panel
PostPosted: Fri Feb 27, 2009 4:51 pm
Monkey Federation (Top 10)*
Looks like you're just about done mayne!
PostPosted: Sat Feb 28, 2009 10:34 am
Nearly. I HAVE to be done by April, because I'm taking it back with me when I visit family and I'll present the case to him.
