It is currently Sun Jan 25, 2015 7:27 am
 Post subject: Old case power button connector doesn't fit new mobo
PostPosted: Fri Dec 26, 2008 9:46 pm
I just replaced the dead mobo in my Acer Aspire E380 case with an Asus M3A78-CM but I can't connect the front power button(or any front leds , etc). The connector is different on the new mobo (bigger and different pin layout). The Acer case has a tight 13 pin connector. What should I do?
PostPosted: Fri Dec 26, 2008 10:20 pm
you have two opts. 1. if you can brake apart the connector to individual wires, then you can hook it up that way. or 2. if you cannot brake apart the front pannel connects, then you'll have to make your own.
seperate each two wires from your power switch, reset switch, front panel leds, etc. strip the wires and attach these items to their respective ends:
http://www.performance-pcs.com/catalog/ ... ts_id=2618
http://www.performance-pcs.com/catalog/ ... ts_id=1730
plug them in. that's it.
PostPosted: Fri Dec 26, 2008 10:23 pm
sometimes I get a 3 pin connector w/ my store bought leds and I have a 2 pin connector outlet. so, I'll use sisors and just cut out the third empty connector. basically making my own two pin connector
