It is currently Sun Jan 25, 2015 5:16 am
 Post subject: Wiring in a "panic button"
PostPosted: Fri Aug 29, 2008 2:07 pm
Team Creamsicles
Team Creamsicles
Or, switch in this case.
Hello all!
I want to wire in a small micro switch and mount it on my case that would instantly shut-down my rig in a required situation. Nothing weird here, I just play Hellgate:London mostly in hardcore-elite mode which means death is permanent. I know this is not great for the computer to do such a thing, but it is a risk I am willing to take. It would not utilized very much.
Anyway, I have a couple ideas how to do it, but I want to be right the first time. I would like ideas of the best way to go about this task, where to tap into, etc.
Much appreciated!
PostPosted: Fri Aug 29, 2008 2:44 pm
Million Club - 5 Plus
why not just hit Reset? it would accomplish the same thing, instant game and OS stop. if its not in a good place just extend it to a convenient place, even the desktop.
PostPosted: Fri Aug 29, 2008 3:20 pm
Team Creamsicles
Team Creamsicles
That's just it, it isn't in a terribly convenient place. An Antec 900 case that sits on top of my desk. that reset button is pretty hard to access in a panic situation. I guess I could just relocate the wiring for that switch to the upper plastic part, where the big top fan is.
My main idea is to have it wired in the PSU wiring. Effectively making my toggle switch like the on/off switch on the back of the PSU. it has to be on for any power to be able to be sent. I just can't quickly hit that switch on the PSU or the case's reset switch.
I have the breakdown of what wire is what in the 24-pin molex plug, but not quite sure if there is a single wire in there that makes the magic happen where I can just wire my switch in-line with that.
PostPosted: Fri Aug 29, 2008 3:47 pm
Maybe if you put a switch in the +5V "Power Good" line? Or is that only used for starting the PC? :?:
PostPosted: Sat Aug 30, 2008 5:45 am
i have a crazy idea! dont be THIS SEREOUS about a game..... if your really going to mod your case because your afraid of loosin ga few pixles then be my guest... just lighten up
PostPosted: Sat Aug 30, 2008 9:59 am
Team Member [Top 500]*
Don't know where you are going with all this but can tell you how to make it happen. Here is a 24 pin motherboard connector:
Note the Green wire, there is only one green wire on either a 20 pin or 24 pin motherboard main PSU connector. That is the line you want, called the PS_ON line. When the system starts that line is held at a logic High (using 5 Volt SB power) by an internal pullup resistor in the PSU. When you press the front panel Start button that line is pulled low (common) and the PSU starts. As long as that line is low the system (PSU) will run. That assumes all voltages are within their rated tolerance. Removing that logic low will instantly (as in right now) shut down the PSU.
Therefore placing a NC (Normally Closed) push button in the path of the green wire will cause immediate shutdown when the button is pressed. Breaking the logic low will allow that line to instantly go high as a result of the PSU pullup resistor and you get a very hard shutdown.
Keep in mind when this happens it is like yanking the plug on a running computer. You stand a real good chance of data corruption and screwing your OS.
NOTE: I strongly agree with CharBroiled on this in that doing this instantly is not the way to go. Placing an external NO (Normally Open) button in parallel with your Reset pins on the motherboard would be much wiser. How I told you this could be done will work, that does not mean it is a real bright move.
Ron
PostPosted: Sat Aug 30, 2008 10:06 am
@ OvenMaster
If you want a reasonable explenation of the PWR_ON and PWR_OK this provides some images as to what is going on:
http://www.bearblain.com/the_psu_page_1.htm
Ron
PostPosted: Sat Aug 30, 2008 11:14 am
Along the lines of what Charbroiled and Reloadron already said...
Uplug the case reset switch and relocate it. If you can get an old beat-up case, just pull off the reset switch, add some wire length, mount it on a block of wood, apply some stick-on rubber feet, and put it on your desk.
Or go to Radio Shack and get a momentary switch and some wire. You can add a rocker switch to disable the reset button when you don't want to use it. If RatShack doesn't have pin connectors, dig up an old component (fan or broken powersupply if you have one) and chop off the appropriate connector.
PostPosted: Sat Aug 30, 2008 11:25 am
There is no need to disable the reset switch/button on the case. The existing RST button is a normally open push button switch. Pressing the switch causes closure (momentarily for the duration the button is held). Just place another normally open momentary push button switch in parallel with the existing RST switch. This is easily done by tying into the existing wires on the motherboard header for RST.
Ron
PostPosted: Sat Aug 30, 2008 11:39 am
Ron
I was actually thinking about disabling the remote reset switch with a rocker so it doesn't get hit accidentally. The case switches are usually recessed to reduce the chances of accidental reset.
PostPosted: Sat Aug 30, 2008 11:51 am
Reloadron wrote:
@ OvenMaster
Ron
Thanks, Ron. I totally forgot about the difference between the two. :oops:
PostPosted: Sat Aug 30, 2008 12:24 pm
@ Edward6287 no problem at all. Me thinks on his case you about need something to poke the sucker. Good point on accidental reset.
@ Oven Master you are quite welcome. I made those charts in the link during my fanatical PSU days.
Ron
PostPosted: Sat Aug 30, 2008 4:56 pm
Team Creamsicles
Team Creamsicles
Excellent, thank you all for the great input. I know killing the power cold is not the way to go, one of the ideas with the reset switch is what I had not thought of and why I wanted to ask for more ideas. Very appreciated! :D
This post was unnecessary trolling. I don't need to be told to lighten up in poor English, I want to do this because I like to do things like this.
I know, don't feed the trolls, but sometimes they just get under my skin.
Thanks again to the actual help!
PostPosted: Sat Aug 30, 2008 5:07 pm
OK we will see if we can't have Jacob938 taken out in the morning and shot at sunrise.
Seriously, I doubt he was trolling. More like just voicing an opinion. I wouldn't worry about it. Just take the good advice for what it was worth.
Ron
PostPosted: Sun Aug 31, 2008 4:55 am
not trolling just stating an opinion, and dont accuse someone of trolling if you dont look at there other posts.
case pic
off of seeing the front... it looks like you could use the bottom plate where it says antec as a button so it still looks good and its functional
PostPosted: Sun Aug 31, 2008 5:47 pm
What exactly is "hardcore-elite mode?" Is it something to do with the game or some kind of name you made up for overclocking the pants off your hardware?
Also, someone mentioned putting a rocker switch in before the momentary reset switch that you're tying in so you don't accidentally reset by accident. A good idea would be to use one of those military-style switches with the red flip covers. =)
And... jacob. epic fail! It took me a little bit of time to figure out why the tables were broken.
PostPosted: Sun Aug 31, 2008 6:06 pm
[url=http://www.website_url.com] Link Description Text [/url]
PostPosted: Mon Sep 01, 2008 5:38 am
OOOOOH POOP! after i made the linky smaller i had some internet problems! damit probably didnt hit submit before it went down XD ill fix now
PostPosted: Fri Sep 05, 2008 8:47 am
clap on, clap off.
PostPosted: Sun Sep 07, 2008 1:11 pm
Team Creamsicles
Team Creamsicles
Thanks for the help guys, I figured out what I want to do.
Jacob, no harm meant, it's just that in the world of gaming forums, that first reply is considered trolling, flame-baiting, etc. When someone askes for help to accomplish something, and someone basically says "hey that's dumb, just relax.." it's considered trolling. It is rampant in gaming forums.
But anyway, point taken, thank you. I just get so deep into the gaming thing, I forget how other forums operate :oops:
