It is currently Thu Feb 26, 2015 11:34 pm
 Post subject: MODing a mac
PostPosted: Mon Aug 25, 2008 4:48 pm
Team Member Top 250
Team Member Top 250
just something that i'm kind of curiously about.
MAc makes some truly powerful architechure in the Pro (tower) line but the cooling is atrocious, one look at a monitor program show internal numbers if the 6-80 range on the ram board and CPU. Anyone have any horror stories or victories with adding water cooling or additional are to a Pro?
And rember Mac can install windows so it is relevent to MAx PC :P
PostPosted: Mon Aug 25, 2008 5:20 pm
Location: Someplace between here and there... I think... I dont know anymore...
Here is a couple of links for you to check out.
http://www.s155158671.websitehome.co.uk/
http://www.xlr8yourmac.com/systems/watercooled_MDD_G4/watercooled_mdd_g4.html
http://homepage.mac.com/steve.smedley/quicksilvermodsw.html
Hope this helps get you started. Would love to see what you can do with a Mac, since there doesnt seem to be a lot of people that have attempted this.
M[/url]
PostPosted: Wed Aug 27, 2008 9:29 am
Team Member Top 250
Team Member Top 250
http://store.apple.com/us/browse/home/s ... co=MTE3MDQ
Check the gallery link, that the mac we have. Doesn't have a lot of room for modding that i can see but i was wondering could a fan be mounted on the side panel (with a hole cut of course) and a external power supply rigged in so its self powered and adding some much needed air to the inside?)
