It is currently Fri Feb 27, 2015 9:02 am
 Post subject: Mod case so motherboard tray is removable
PostPosted: Mon Aug 25, 2008 1:16 pm
Anyone here have any thoughts on making the motherboard tray removable.
I've seen several cases i really like for a new system but none have a removable MB tray and the ones i find with them are very $$$.
It seems it would be any easy mod.
PostPosted: Mon Aug 25, 2008 3:44 pm
Team Member Top 100
Team Member Top 100
http://www.performance-pcs.com/catalog/ ... ts_id=3387
get that, and mod it to slide in and out of your case...dont ask me about the modding part, idk, just thought that may help... ;-)
PostPosted: Mon Aug 25, 2008 4:56 pm
You'd prolly have to drill out the pot rivets holding the original tray to case. In addition you'd have to cut the rear of the case out (I/O sheild, PCI slot, etc) so the tray could slide out. Lastly, you'd have to find a way to secure the new tray once you install it. That means building a track to slide it in/out or driling holes to screw the motherboard tray into the case.
Not to mention re-riveting the case so it doesn't fall apart, as the tray is probably part of the structure as well.
Just kinda thinking out loud. It'd be a big project
Your right, the cases that come with the removable tray are more expensive, but they are usually of higher overall quality. I bought a Lian Li several years ago for $100, and its a great case.
PostPosted: Tue Aug 26, 2008 9:22 pm
denyasis and nebbuchanezzar
Thanks for the advice.
The Lian Li Replacement Removable Motherboard Tray - PC-6X
would be the way to go for modding a case.
Through the performance-pcs.com web site i found (previously unknown) Ultra cases.
I Purchased the Ultra Aluminus ATX Full-Tower Case
http://www.ultraproducts.com/product_details.php?cPath=13&pPath=411&productID=411
through Amazon.com for $86 total!
2 great finds and a case!
performance-pcs.com
ultraproducts.com
