It is currently Mon Apr 27, 2015 6:53 pm
 Post subject: Airflow
PostPosted: Mon Aug 25, 2008 6:51 am
I'm looking for links to case airflow diagrams, with fan positions and sizes. Any help would be appreciated.
PostPosted: Mon Aug 25, 2008 7:16 pm
Don't have any links, but the principle is that airflow is from front to back and bottom to top provided you're building a fairly traditional case. A typical case with decent airflow would have a 120mm intake fan at the bottom of the front panel and an exhaust fan directly across from the CPU on the back panel. Some cases have a top panel exhaust fan. Consider fan filters on all intake fans; helps reduce dust inside case.
PostPosted: Mon Aug 25, 2008 7:26 pm
Million Club - 5 Plus
You mean like this?:
 Post subject: Thanks
PostPosted: Tue Aug 26, 2008 7:30 am
Thanks for your help.
