It is currently Fri Mar 06, 2015 12:06 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 19 posts ]
 Post subject: how do I wipe my hard drives clean?
PostPosted: Sat Aug 02, 2008 3:52 pm
Hi guys
Hope this is the right section
I'm building a new rig thanks to the help from Maximum PC's forums. I'm going to selling my old rig so I'd like to wipe the hard drives (120GB & 300GB)clean. Any advice?
Thanks guys
PostPosted: Sat Aug 02, 2008 5:23 pm
Million Club - 5 Plus
DBAN
PostPosted: Sat Aug 02, 2008 9:44 pm
CharBroiled wrote:
depending on the method of wiping you use and the size of the drives be prepaired for this to take a while, possibly around 24 hours if not longer.
PostPosted: Sun Aug 03, 2008 7:02 am
Team Member Top 250
Team Member Top 250
Format the drive in on a live disk of Ubuntu. Don't select the quick format, because that just deletes the MFT, you want to erase the entire drive.
PostPosted: Mon Aug 04, 2008 7:17 am
Formatting is not the same as wiping a drive. We are talking about writing zeros or random characters to every sector of the drive making any private data virtually unrecoverable.
PostPosted: Fri Aug 08, 2008 6:26 pm
Team Member Top 250
Team Member Top 250
Oh, Than won't a strong magnet do?
PostPosted: Fri Aug 08, 2008 6:44 pm
No. A strong magnet will not do.
A good overwriting program used correctly will make the data unrecoverable without special equipment. If you want to use a magnet, you'll have to find a bulk eraser that is designed for hard drives. If you don't have space aliens or the Illuminati's tech department looking for your pr0n collection, DBAN or another good eraser will do what is needed.
PostPosted: Sun Aug 10, 2008 5:18 am
bathtbgin wrote:
DBAN is the only fail safe solution. Do it once, do it right!
 Post subject: Re: how do I wipe my hard drives clean?
PostPosted: Mon Aug 11, 2008 9:32 pm
Team Member Top 1000
papalarge wrote:
Hi guys
Thanks guys
Take a drill and drill holes through it! That aught to stop data thieves! :D
PostPosted: Sat Aug 23, 2008 8:42 pm
Format your hard drive (quick). Write a batch file that copies random files to your hard drive until it fills up, then format it again. :wink:
I've seen some hard drives fail from complicated destruction programs (disk wipers) :shock: . They are so cheap now I quit crying about it. :twisted:
My first Raptor -- ouch.
PostPosted: Sun Aug 24, 2008 12:17 pm
Many apps will write a drive to MilSpec values, but so will writting zeros really. You can full format the drive, write zeros, and end up with a drive I'd be comfortable selling.
Can you get the data? Ya, but you gotta work your ass off with a hex editor. I rate the odds that some eBay buyer is out there buying drives just to get random info off the drive as very, very, very slim. If I was buying a drive, I want to use it right away. I format it, use it, don't care what was on it.
So I just think all this extra work to get some magical (sarcastic...un-important info) off the drive as a moot point. Even encrypting the entire drive would keep n00bs from seeing what was on it without formatting.
Just being overly cautious, which is a good idea, but redundant to the purpose of the sale. Even DOD type encryption can be cracked if they care, so do they? 99.8% they don't.
PostPosted: Thu Jan 01, 2009 3:30 pm
go to hard drive web site and download program to o out drive this is also known as low level format
PostPosted: Thu Jan 01, 2009 3:36 pm
Active@ KillDisk -- > http://www.killdisk.com/
There you go! Free version works well!
AJ
PostPosted: Thu Jan 01, 2009 4:33 pm
AJ
Does this really work?!
PostPosted: Thu Jan 01, 2009 4:39 pm
AJ
I burned it onto a CD and it totally wiped these two hard drives I have in an older system. It's a legitimate program.
AJ
PostPosted: Mon Jan 05, 2009 2:00 pm
Million Club
Million Club
Only in movies dude. It would take a supercomputer running 24/7 more time to try every possibility in 256-bit AES encryption than the Universe has existed. 256 to the 256th power.
PostPosted: Mon Jan 05, 2009 2:20 pm
Monkey Fed [PC]
Monkey Fed [PC]
Epic thread back from the dead syndrome!!!
PostPosted: Mon Jan 05, 2009 5:48 pm
Oh crap...didn't even realize it... didn't mean to contribute to it.
BAD AJ!!! *facepalm*
AJ
PostPosted: Sat Jan 10, 2009 7:28 am
I'd rather be modding!
Locked - Wrong section anyways.
