It is currently Thu Mar 26, 2015 2:40 pm
 Post subject: odd CPU heat?
PostPosted: Fri Aug 01, 2008 4:44 am
specs
E2160 @1.8 currently
p35 ds3l
550W corsair
2x1g
well what happens with my CPU is when i turn on my PC for the first 2 minuets it will idle at about 35C and after the 2 minuets it will go back to 25C. is it common that systems will do this? or is mine just retarded? i rolled back overclocks for summer and now i want to re-OC..... is this fine or somthing i should be worried about. really theres a bit of dust in the case and im cleaning it out today. before in winter/fall it would idle 21 and 28 on startup. input plz :D
PostPosted: Fri Aug 01, 2008 5:49 am
it gets hot when it loads up all the processes and drivers
PostPosted: Fri Aug 01, 2008 8:20 am
thanks, and sorry guys, wrong section :wink: dunce moment
