It is currently Fri Feb 27, 2015 5:37 am
 Post subject: i want to make a fallout case mod, need ideas
PostPosted: Tue Jul 29, 2008 3:53 pm
i want to make a case mod themed from any of the fallout series . i need any ideas that anybody can through my way . one thing i was thinking about was fabbing a micro fusion cell to house a water cooling radiator . any help would be great .
PostPosted: Wed Jul 30, 2008 4:35 am
i would think the big guy with the gas mask on one side with fallout next to it, and everything done in a worn down style maby some mesh thats pulled back and somthing petruding out of it
http://www.mnpctech.com/Custom_Black_PC_Fan_Grill.html
those look insaine when there painted in a worn down style
PostPosted: Wed Jul 30, 2008 1:19 pm
a bunch of stuff i bought on ebay came today . i got a bunch of those old vacuum tubes , like you can see inside the pip boy 2000, and a bunch of orange diffussed leds . i used a dremel with a glass cutting bit to bore a hole in the bottom big enough for the led to fit inside , about half way up . not like the real thing but better than i thought it would be . i have a few more ideas its just the implementation into the case . when i get started i'll post pics . any more ideas would be welcomed :D
PostPosted: Wed Jul 30, 2008 1:25 pm
forgot to mention i found a 2 or 3 part system for rusting any painted surface , from modern masters . i'm going to give it a try . i'll let you know how it goes ... when i get started :D
