Mogul20478 wrote:
Hey, I have a NZXT Hush Silent Gaming Case, and want to put in a clear side window. The only probleme is I do not know what I could use to cut the metal. Does anyone know what I can use?
Jigsaw, with a metal cutting blade I won't use anything finer than 12-20 tpi, or you'll be at it all day.
You're talking about cutting somewhere in the range of FOUR feet (if you took the corners out and stretched it out straight). I don't know about you, but I wouldn't want to use a dremel to cut across the width of a sheet of plywood?
A few tips from personal experience:
Do your markings on, and your cutting from the inside.
Measure at least a few times before you cut (I'm sure you've heard that one a few times).
Don't drill your starter hole right on the cutting line. Drill inside of the hole, the cut your way over to the line.
If you want tighter corners than the saw blade will cut, sawcut the straights and dremel (or a small grinder in a drill) the corners.
