It is currently Sat Jan 31, 2015 1:20 pm
 Post subject: TF2 case mod in concepting
PostPosted: Sat Jul 26, 2008 9:45 am
well, iv decided to do a TF2 case mod to commemorate my clan aswell as TF2 itself. this is my first mod and these are some of the very rough sketches that i have drawn up. i was thinking about the right side doing the letters bigger and cutting in all out, meshing behind it with mesh painted TF2 orange.... and then putting some led's behind it to eluminate (SP?) it . i also plan to remove the centiuron 5's factory fans with 2 120MM orange leds which can be seen here:
http://www.performance-pcs.com/catalog/ ... ts_id=1364
remember... these are very rough sketches and im still in concept... pitch me ideas if you have any... and thanks!
REMINDER: throughtout the pictures ignore the black boxes and little grey spots.. they were simply mistakes and will not be painted like that. they will be left the stock color
LEFT SIDE AND FRONT:
STOCK:
CONCEPT:
top is being re-done because first idea didnt really seem great to me, or anyone i asked.
RIGHT SIDE:
STOCK:
CONCEPT:
PostPosted: Sat Jul 26, 2008 3:37 pm
awesome idea
PostPosted: Sat Jul 26, 2008 4:06 pm
ty... mind if you guys give some input wether or not i should cut out the right side and put the led's behind it or just stick to paint... im really ont sure because of my experience level :?:
PostPosted: Sat Jul 26, 2008 8:18 pm
It'll be cool either way. I think that case has two plates on the right side, tough. That means that a mesh window would look into another sheet of aluminum about a quarter inch behind it (which holds the mobo). LEDs could shine through, but that's about all that would. I'm a big fan of the orange/black color scheme.
PostPosted: Sun Jul 27, 2008 5:11 am
guess im going orange black then! anyways im pretty sure on the right side it will say TF2 NEWBS in big letters below the icon.... thats it.
