It is currently Thu May 23, 2013 12:00 am
 Post subject: Antec Super LanBoy mod
PostPosted: Fri Dec 17, 2004 5:23 pm
I just got an antec super lanboy. I realy dont like that blue cover in the front. Any advice to replace it with?
some day i hope to replace the fans with green led fans and I have have the use of a glass(will work on acrillyc) sand blaster that can blast an image into the clear window, im just waiting to find the perfect image to be imortalized in the case
Stock super lanboy:
http://www.newegg.com/app/Showimage.asp?image=11-129-145-04.JPG/11-129-145-07.JPG/11-129-145-06.JPG/11-129-145-05.JPG/11-129-145-02.JPG/11-129-145-01.JPG/11-129-145-03.JPG/11-129-145-08.JPG&CurImage=11-129-145-04.JPG
PostPosted: Fri Dec 17, 2004 8:46 pm
just look around and see if there are any screw to remove and then search around mod retailers to see if they have any of those covers for you
frozencpu.com might have some but not sure
PostPosted: Fri Dec 17, 2004 9:45 pm
yeah the cover pops off easy but the fan under is a 120mm fan and its smaller than the cover, so a fan cover would be a little to small
PostPosted: Mon Dec 20, 2004 3:17 pm
any have any pics or licks of modded super lanboys
