It is currently Thu Feb 26, 2015 3:33 pm
 Post subject: Upgrade internal laptop speakers?
PostPosted: Wed Jul 02, 2008 1:17 pm
Are there any vendors that sell laptop speaker upgrades? The internal ones on my Toshiba Satellite A75-S229 are crap. I realize that an external solution would be the best solution, but id like to sink some cash in the internal ones.
PostPosted: Sat Aug 30, 2008 8:47 am
King of All Voodoo2 Cards
I've found on my Clevo laptops that the speakers are removable, but it appears that the laptop itself was engineered specifically for those speakers (ie- the way the speaker fits into the chassis), and unless the upgraded speakers had the exact same form factor and impedance, I don't think you're be impressed with the results.
PostPosted: Sun Aug 31, 2008 6:13 pm
I think the laptop speakers are basically the same ones used in headphones but they are amplified so its loud, but i would agree with flytrap7.
