It is currently Wed May 06, 2015 4:40 pm
 Post subject: Wire Management
PostPosted: Wed Dec 15, 2004 11:09 am
i was wondering if anybody could link me to a site that gives pics of how to do a really good wiring job?
i just did mine but i dont really like it, the wires are all nice and hidden but theres little things that i see that bother me
thanks for any info
PostPosted: Wed Dec 15, 2004 4:15 pm
King of All Voodoo2 Cards
D you use cable ties at all?
PostPosted: Thu Dec 16, 2004 12:15 pm
yea i use cable ties and some of those adhesive hooks for the side but my problem is that there is a big bunch of wires at the top the case right where they come out of the psu. and i want to try and get rid of it. i was just wondering if anybody had any technique tips and if there was a site that could also help.
PostPosted: Thu Dec 16, 2004 2:15 pm
Don't know of any good how to's..I usually go to modding sites to get ideas(MRL sticky has lots of sites).
do you have any pics of the inside of your case? maybe someone here can give you some ideas :)
PostPosted: Thu Dec 16, 2004 2:37 pm
if theyre unused wires coming out of ur PSU, u can just open it up and cut em off really really close to the soldering point (or just desolder em)
PostPosted: Thu Dec 16, 2004 8:58 pm
i use the wires but thier is just a big bundle of them right where it comes out
it just looks ugly, but i guess ill just have to try some things and see what works out
PostPosted: Fri Dec 17, 2004 6:30 am
well, you could get some cable wrap and wrap it, then stick it behind (on the other side of) your drives. I do that and it looks very need. just run it down the back of the case and even behind the mobo. you may have to take the board out and play with some things, but if your PSU cables are long enough, they should be ok.
PostPosted: Fri Dec 17, 2004 10:52 am
alright ill have to try that
thanks for the tips though
