It is currently Tue Mar 31, 2015 5:27 am
 Post subject: Water block mounting bracket
PostPosted: Sat May 24, 2008 8:08 pm
I had to mod a bracket for a water block from my Thermaltake 735 kit.
I bought this kit for 50$ after a gift card and mail in rebate. It has cooled 3 of my AMD chips and now on the 4th. Being that it was made for 939 It didn't fit the AM2+ mobo very well. I thought there was a bracket but I guess I was wrong.
So I decided to make one. I was told be careful not to crack the water block and I've had no problems.
Cooling my 125 watt TDP phenom with ease with temps @ 38C idle and 44C @ full load AOD stress test for over a hour @ stock speeds.
If you look close and see additional holes, That's the idea of it. I can still mount it to 939 (the hole closest to the block) and possibly Intel boards also with the holes drilled in between. (I haven't tried an Intel board yet)
A budy of mine has like 7 Intel PC's and won't give one up for testing and or overclocking / modding. Intel fan boy needs an arm twisting. He knows who he is that I speak of lol right S....y??
Yea the blocks turned due to the fact the are no centered mounting screw holes straight up and down. I thought this would be a problem but it looks as if It just makes it.
That's my most recent mod hope you like it. :D
PostPosted: Mon May 26, 2008 12:50 pm
I'd rather be modding!
Now that is the spirit of modding!
The clearance scares me a bit though.
Manta
PostPosted: Fri Jun 13, 2008 2:22 am
Indeed. Did you ever consider, though, doing an "S" shaped bracket, in order to get the block straight. IOW, a right angle at either end of your current bracket. As long as the material and design are sound, it will hold plenty solid enough.
PostPosted: Mon Jun 16, 2008 1:09 am
Engineering aside, it's done. It's a mod.
