It is currently Mon May 04, 2015 3:21 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Jul 07, 2008 6:50 pm
awesome setup
PostPosted: Mon Jul 14, 2008 4:24 pm
So I found a square bar that was left over from Hard Drive PC and cut a hole for the bar to feed all the way to the bottom
I'll have to cut holes as marked for each level to feed in its SATA Cable
I'll be able to mask the onslaught of cables that I may have in this project.
I still need to find a seal of some kind at the top to lock the bar into the plexi
Same goes for the bottom. I'm thinking rubber or silicon maybe?
PostPosted: Sun Aug 17, 2008 1:09 pm
Framed is pretty much done. I'm in the process of loading XP onto all of the drives.
PostPosted: Mon Aug 18, 2008 7:40 am
Monkey Federation (Top 10)*
TheGreatSatan wrote:
What the heck is that yellow thing?
PostPosted: Wed Aug 20, 2008 8:14 pm
New Concept photo.
I just need to buy the bracket which will hold the LCD on top. Maybe you can help. I need a bracket like the one I drew up. I don't know where to start looking for one, but I may have to make one myself.
