It is currently Tue Apr 28, 2015 5:06 am
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu May 29, 2008 12:11 pm
how about you add a liquid cooling setup that attaches to all the Cpu's and motherboards.
PostPosted: Thu May 29, 2008 6:34 pm
How about not....
PostPosted: Fri May 30, 2008 7:33 am
I added the stand-offs
I added a little silicon to hold them in
I'm using thumb screws to hold on the removable side, but don't have enough yet.
So here's where we are now. I'm waiting for the PSU's to come and I'm going ot start on the individual front plates for the DVD drives and Power Switches
PostPosted: Fri Jun 06, 2008 9:11 pm
My PSU's arrived
And I cut off the excess wires
Then I attached the first one and discovered a problem.
If I have one PSU for each system and bolt them all in to the frame, I will not be able to slide each of the motherboards into place. The PSU below will always be in the way of the motherboard above.
So, I will use one PSU and snake the motherboard connection through each level until I plug it in the system I need to run.
I guess I cut all those wires for nothing.
PostPosted: Sun Jun 08, 2008 5:58 am
Team Member Top 250
Team Member Top 250
TheGreatSatan wrote:
I guess i cut all those wire for nothing.
No you didn't, you cut those wires with the intention of using one PSU for each motherboard, now that you've learned that you cant, than another solution is needed. It's a learning experience.
I still don't understand why the motherboard will hit the PSU. Could you elaborate a little?
PostPosted: Sun Jun 08, 2008 6:28 am
PostPosted: Sun Jun 08, 2008 3:54 pm
We have the same rotary. I love mine, awesome Craftsman quality, as usual.
PostPosted: Mon Jun 09, 2008 10:44 am
I'd rather be modding!
It won't work TGS.
One PSU will not power all 4 boards at the same time - no matter hw big it is. It's a PSU design issue.
You might look at one of trwo solutions....
First, It looks as t6hough you can get two PSU on the top and maybe two on the bottom?
Second, you might even consider a separate power case and put all the PSU in there rather than on the rack. You might also beable to mou8nt a few things up side down on the rack to get yourself some more room.
PostPosted: Mon Jun 09, 2008 8:18 pm
MantaBase wrote:
It looks as though you can get two PSU's on the top and maybe two on the bottom?
U may even consider moving the KVM switch to the very top, in order to execute it properly. Have u given consideration to actually de-casing the PSU's, and grounding them to the rack? That's even more "mod", and would allow u to fit all 4 on the same tier.
 Post subject: re: 5xmod
PostPosted: Tue Jun 10, 2008 6:28 am
GS,
Nice build you have going. PS's won't fit, bummer. Did you not do a dimensional layout?
U know I was messing with putting a PC in a dewalt drill case (just for laughs), and I couldn't get my PS in there with the mother board, but I did investigate taking the PS out of it's case which could save u a lot of room.
Then u could mount the fans seperate form PS's and save that room. Group mount the PS together and orient a few large fans at the whole bunch. Without cases it should help the heat dissipate too.
I mean the way ur build is looking(cool) the PS cases are not very attractive anyway, :).
PostPosted: Tue Jun 10, 2008 7:45 am
Don't power supplies have cases on them for a reason? Isn't it a little bit dangerous de-casing them and then asking them to run like that? Just curious. :o
PostPosted: Tue Jun 10, 2008 8:27 am
you might have been better off if you looked for rack power supplies, ones for a 1u, or 2u . they are very small and quite efficient. or the ones that power shuttle boxes, also quite small.
PostPosted: Tue Jun 10, 2008 7:52 pm
MantaBase wrote:
It won't work TGS.
I thought I was abundantly clear. Only one system will be powered at a time. These are test systems. For instance, someone will need RAM tested. I'll open the side panel, connect the PSU to the board, add the RAM, and boot it up. NEVER will I run more than one at a time.
Work will commence whenever I choose the hard drives
PostPosted: Thu Jun 12, 2008 8:34 am
MantaBase wrote:
It won't work TGS.
I must have missed that TGS - my bad.
PostPosted: Tue Jun 17, 2008 4:59 pm
I got mail!
PostPosted: Fri Jun 27, 2008 3:28 pm
TravBv2.0
TravBv2.0
Looks like it's coming along really nice. I wish I could offer some input on the PSU situation. Is there any such thing as a switch that allows you to switch between different boards with one PSU? Is this something that couldn't conceptually work? or is it just too much of a bitch to try and make? It seems to me like the cables are like train track. get enough switches and you can make that power go where ever the hell you want to, right?
PostPosted: Sat Jun 28, 2008 6:55 pm
I wish.
PostPosted: Sun Jun 29, 2008 6:35 pm
I'll get more done soon. My wife has had the week off and doesn't want me modding while she's home, because I'm not spending time with the family.
PostPosted: Tue Jul 01, 2008 5:04 pm
Location: Someplace between here and there... I think... I dont know anymore...
I had that problem before too with an exgf. Traded her in, and now have a wonderful wife to be, that lets me have more than enough space to do as I wish without feeling guilty.
Cant wait to see the outcome of this system(s) build once you get a chance to sneak away. Concept sounds awesome.
PostPosted: Sun Jul 06, 2008 8:52 pm
Alright, more wonderful news.
I've decided to use 1 slim external DVD drive for laptops (powered/runs off USB). This was becuase I was mounting the DVD drives when I realized that the drives will cut off a lot of airflow in the system. Also, I decided that I would mount all of the hard drives on the bottom behind the KVM switch and run the SATA cables up to each board.
Then I discovered another hiccup. The Single core AMD mobo does NOT have a SATA connector! :( All I bought were SATA HD's!! Now I'll have to get one IDE drive for the lone mobo at the very bottom. of the rack. Here's the current direction:
