It is currently Sun Mar 29, 2015 12:18 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: the poll on top
PostPosted: Sun May 04, 2008 8:29 pm
I'd rather be modding!
KURTLEYBA wrote:
oh also, I didn't mean to add a poll--I was just messin' around with the feature since I am new to this forum stuff. I accidently published it and I don't know how to take it out.
Chill :)
A finished rig is ready for submission --always.
I'll see about removing the poll if you want.
Look guys - we are MPC. It's time we represent. Enter that rig at the ModShop and make sure you put MPC as a tag! Send it in for ROTM.
My only advice is better pics.
PostPosted: Sun May 04, 2008 8:32 pm
Poll deleted.
BTW - the results were pretty good :)
 Post subject: MAXIMUM PC RIG OF THE MONTH CONTEST
PostPosted: Mon May 05, 2008 12:46 am
MantaBase
thank you sir. this week I will get a nice digital camera and take some professional type pics the best I can. I will build a back drop in my dining room. then, I will enter it into the ROTM. but first I'm gonna build the smoke stack/ fake slime tank that I had mentioned earlier.
check out the pic thread:
KURTLEYBA wrote:
I'm gonna use another member's idea (Skitzo) of a fake holding tank for the green slime on top of the case. I am gonna fabricate another box-like housing out of white styrene sheets; I found an actual smoke generator from MicroMark that is made for model trains. it is designed for building models. it is very small w/ a changabel smoke stacks. I will have this fake tank w/ smoke coming out of the top. I will place this smoke/tank/housing on top of the case toward the back. here's the pic of this cool part
By kurtleyba at 2008-05-04
[b]Also, I'm gonna do the LCD MOD:[/b]
also, I am going to mod my 22" LCD frame to look like that Capital One commercial where their building their custom credit card instead of the monster. in the background, there is a tv that has rivets and has rust water stains running down the sides. It looks like it should be in Quake4 or in Mars City. I can't wait to get started.
I've ordered some half circles from US Plastics made out of acrylic, which will work great as fake rivets. I will paint the LCD frame and base with Alclade aircraft metal paint. then, of course, apply the rusting material.
then I will enter the rig.....It would be really cool to see my case in a National mag!!!
PostPosted: Mon May 05, 2008 7:22 am
I think you should try to dye the smoke green somehow.
PostPosted: Tue May 06, 2008 11:47 am
That would look sick, I would use a green LED to light the smoke green.
