It is currently Sun Mar 29, 2015 9:25 pm
 Post subject: how to paint?
PostPosted: Thu Mar 27, 2008 9:52 am
alrighty i'm thinking of using spray paint for a mod im doing i was thinking of doing 2-3 coats of primer and 3 coats finish.... and im using a stencil to do lettering the letters are going to be a silver/gray and the rest of the case is going to be a royal blue sorta look like a blue mustang.
anyways any thoughts would be appreciated :idea: :idea: :idea: :idea:
PostPosted: Thu Mar 27, 2008 3:07 pm
What kind of thoughts are you looking for? Will it look good? Is there a better way to do this?
All I can say is it should look good, just make sure to sand in between coats of primer and I hope you have an incredible steady hand if you're using canned spray paint.
PostPosted: Thu Mar 27, 2008 7:55 pm
well i was already planing on sanding between coats of primer....thanks for the steady hand tip :)
PostPosted: Fri Mar 28, 2008 5:41 am
See my extensive How-To
