It is currently Sat May 18, 2013 1:21 am
 Post subject: Case LCD Question?
PostPosted: Wed Dec 08, 2004 10:53 am
I am planning to put a text-line LCD in my PC and I was wondering how I was to about doing it. I know where to buy the LCD...
http://www.crystalfontz.com
...but, how do ya'll think i should mount it? They have drive bay mounts, but I was thinking a mod for inside the computer, visible through my window....
I see these things in a whole bunch of custom $4000 PC in the mag...but where, or what, can I do to enjoy the same bliss?
PostPosted: Mon Dec 13, 2004 11:25 am
I am still wondering about this mod. I know this is a harder one to do, but it definitely (note that it is spelled correctly) looks like one of the coolest!
Please! I need some feedback!
PostPosted: Mon Dec 13, 2004 1:42 pm
why do you just glue it on or something....
PostPosted: Mon Dec 13, 2004 2:57 pm
That is exactly the answer I thought I was going to get. I really wanted people to give advice on what they have done to their systems. Has anyone out their experiemented with this? I know it looks really cool and could be really easy, but what are some ideas?
PostPosted: Mon Dec 13, 2004 3:15 pm
Monkey Federation (Top 10)*
What's your window made out of?
I would reccommend attaching a clear shelf to the window (a thin piece), and then glueing the bottom of the LCD thingy in your link to the shelf. That would very clean assuming your window isn't made out of glass.
PostPosted: Mon Dec 13, 2004 3:25 pm
It is the regular plastic case windows stuff. Thanks for the info, would anyine like to elaborate and give ideas regarding how they did it?
