It is currently Thu Mar 26, 2015 3:24 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Mon Oct 06, 2008 10:55 am
The bezel. The whole front. I want to add the mesh here too, but I'm not sure
PostPosted: Mon Oct 06, 2008 8:55 pm
So I needed work on the front.................with bondo
I prepped my mesh
Before I painted and bolted it on I needed to cut out the Power and Reset buttons
Here's how it's going.
Then I painted and added the rivets
Then I cut out the blow hole and added the mesh
And painted the rivets too.
I added the lone slot loading DVD drive
Nearing the end
PostPosted: Wed Oct 08, 2008 11:57 am
I drilled holes for the carry bars to mounted to the sides.
I'll be using countersink nails
I've been meaning to touch up the angel topper. I bought some wood filler for the seams where the decorative trim pieces come together.
Once it dried I reapplied an extra thick coat of paint to assist in the fill in
I cut out another piece to stealth the DVD drive and I'll add it in a bit
PostPosted: Wed Oct 08, 2008 8:11 pm
Wow, Very nice!!
Am I correct in guessing that the New carry bars are going to be attached to the square bars on the bottom, or are you replacing them completely?
I particualry like the from bezel work - its slick!
PostPosted: Thu Oct 09, 2008 4:49 am
Yes!
PostPosted: Fri Oct 10, 2008 4:17 pm
I stealthed the DVD drive
