It is currently Fri Mar 27, 2015 6:25 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Jun 13, 2008 5:22 pm
No, but since the idea of the Ark being a computer is fantasy anyway, I just thought it would look good.
PostPosted: Tue Jun 17, 2008 7:28 pm
So more work to show.
This is what I'm shooting for.
Here's how I'll do it. I used good ol' expanding foam to fill in the pillar
I have this thin rod
I had to cut it to size
Then I dropped in the rod
And drilled a hole in the plywood base
I checked to make sure that the rod will fit.
And shaved off the excess foam
Then all I had to do was set the pillar on top and push the rod through the top and bottom.
Three to go. :)
PostPosted: Thu Jun 19, 2008 8:23 am
damit man.... u have got skill and cease to come up with another swift arse idea!
PostPosted: Tue Sep 16, 2008 8:20 am
So it's been months now and I'm finally ready to finish this mod. There will be some changes made to the base and topper because wood looks like crap when painted gold so I'll do something different there.
My Angels arrived and I've painted them!
The pillars were done with tow different kinds of gold paint, but now that I bought more I can match them all.
PostPosted: Fri Sep 19, 2008 6:28 am
First, this looks way awesome. Sweet idea!
Second, what've you tried to make the gold paint on the hardwood look okay? Sanding, priming, filler, etc?
PostPosted: Sat Sep 20, 2008 6:31 pm
I just follow my own painting guide:
http://www.pcmodhouse.com/id64.html
So I finished the 1st part of the top, there's more coming.
I have some old trim lying around that I'll be adding under the topper to transition the 90 degree angle.
I'll also be adding more to the top along the edges making it look far more elegant.
PostPosted: Tue Sep 23, 2008 6:14 pm
The trim has been painted.
Here's where it'll go
I bought more trim too
And these cool knobs
This is how I do my wood cuts. Plain old Miter setup
The two pieces go under the case like this:
And here's what to expect when I add the columns
PostPosted: Wed Sep 24, 2008 7:42 am
Monkey Federation (Top 10)*
All this modding and you're rocking a miter? :lol:
PostPosted: Wed Sep 24, 2008 4:33 pm
Alright, more work on top. I cut and added a sweeeeet chair rail.
So you know where I'm going with this.
Now I'm working on the bars that the people who carry the Ark hold on to. Like here:
I added those cool handles I painted earlier to the posts I cut with the miter saw.
The bars will be bolted to the bottom of the case
More coming.
PostPosted: Wed Sep 24, 2008 7:40 pm
I did a little more work tonight. I cut the rope looking pieces for the topper trim
I used plain old Elmers glue to bond it.
I added the carrying poles to the bottom sides. I still have to physically attach them.
There's more coming to the bottom, including feet.
PostPosted: Thu Sep 25, 2008 11:33 am
I decided to add a different gold to the mix. A shiny gold to the trim and angels.
I found a cool looking top piece too.
PostPosted: Thu Sep 25, 2008 7:19 pm
I've got some more done today. I painted the handles for the carry bars
I have more of the trim still drying, but you get the idea.
You think there are any other places that would benefit from the shiny gold?
I bought these cool thread spools from the local Hobby Lobby that I will be using for the Feet.
The top is done. It all has to dry though
Now I'm working on attaching the transition trim near the top and the handles. The handles are going to be bolted on and they will be able to support the weight of the case when it's all done.
PostPosted: Fri Sep 26, 2008 3:39 pm
Today when I got home from work I mounted the feet. Here's what I need for each
I drilled out one of the spool holes to make it bigger. The screws will go in through the bottom and in to the case
Now the top of the screw will sit flush with the ground
It took a whole 5 minutes total
PostPosted: Fri Sep 26, 2008 8:12 pm
So I attached the other carry bar and one of the front columns and I must say, IT LOOKS LIKE CRAP. I need to find something besides my current column choice to make the front look better.
PostPosted: Sat Sep 27, 2008 7:19 pm
Tomorrow I'm going shopping to fix this. Here's the Ark model I'm using:
And here's the direction I'm heading
PostPosted: Sun Sep 28, 2008 1:10 pm
So I had to rethink this. I bought 4 of these table legs
I then pulled out the screw in one for each side
Then added glue and screwed them together
Then comes the paint.
And here's kind of what it'll look like later
PostPosted: Mon Sep 29, 2008 10:58 am
Much better.
PostPosted: Mon Sep 29, 2008 4:33 pm
I'm not sure about the front. Does anyone have any ideas about what I should do, if anything?
PostPosted: Tue Sep 30, 2008 8:54 am
What do you mean?
