It is currently Thu May 23, 2013 3:27 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Fri Nov 02, 2007 12:32 pm
KAYZER wrote:
If you were to put a fog machine inside the case, the the vapor from the dry ice and the moisture that's emited would fry the electronic components! :idea:
oh my bad :oops: It would've been a good idea if the components didn't freeze. :(
PostPosted: Fri Nov 02, 2007 12:35 pm
If you weren't fond of viewing the $2,000-$3,000 worth of hardware you just put together, yes... :P :idea: :roll: :lol:
PostPosted: Fri Nov 02, 2007 12:38 pm
My dell could heat the ice though :roll: It has a P4, and it's the reason why my room is hot. but not like real hot, just like 78F to 80F.
PostPosted: Sun Dec 30, 2007 7:43 am
Update, KAYZER???
PostPosted: Sun Dec 30, 2007 12:17 pm
I know really, KAYZER when are you updating this? Did you give up? :shock:
PostPosted: Sun Dec 30, 2007 12:30 pm
yes kayser did you? :shock:
PostPosted: Mon Dec 31, 2007 9:21 pm
I'm anxious to see what you did. I just bought this case, and maybe you could give me some ideas...:D
PostPosted: Mon Dec 31, 2007 9:50 pm
Maybe he tried it, and it really did fry his stuff.
PostPosted: Tue Jan 01, 2008 8:23 am
I hope he didn't take my advice.
PostPosted: Tue Jan 01, 2008 11:10 pm
I decided to wait, due to airflow issues, and not having the right (expensive) tools!
I'll let you know when I mod the case...
PostPosted: Sat Mar 01, 2008 4:34 pm
um, dry ice vapor?
PostPosted: Sat Mar 01, 2008 5:11 pm
Quote:
um, dry ice vapor?
lol...EXACTLY
That one is even better.
