It is currently Sun Jan 25, 2015 11:03 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Dec 12, 2004 1:06 pm
Team Creamsicles
Team Creamsicles
Law_Of_The_Jungle wrote:
5 minute mod- take a wee wee on your power supply
good idea.
how about taking a drill and drilling holes all over the place?
PostPosted: Sun Dec 12, 2004 2:34 pm
Or a gun. I found a site once where they modded with a chainsaw, axe, and shotgun.
PostPosted: Sun Dec 12, 2004 2:46 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
that was posted already.........
u guys are freaks of nature if it takes u 5 minuts to pee
PostPosted: Tue Dec 14, 2004 6:02 pm
I shake my fist at whoever got to it first :evil:
PostPosted: Tue Dec 14, 2004 7:37 pm
Team Creamsicles
Team Creamsicles
take a poop on ur cpu and keep it nice and cool.
Sticking speakers on to ur case.
or
Take of 1 of the side panels of ur case and replace it with an lcd screen.
:wink:
PostPosted: Fri Dec 17, 2004 6:39 am
Yeah thats almost a 5 minute mod (assuming you don't hook the lcd up to your pc). :P
 Post subject: They call me "The Rejuvinator"
PostPosted: Wed Jan 26, 2005 6:14 pm
These thread could go somewhere later, plus I am interested in 5 minute mods.
Re-Wire case - Hide wires in any spots you can to improve airflow, temperatures, and looks
Install random fans - I had a HDD cooler with a case that didn't support it.. That didn't stop me!! You can use double sided tape and put a quiet fan on the HD rack decreasing temperatures
Remove LED's - Some people like LED's, including me, but leaving my PC on overnight to Fold is quite annoying, I randomly wake up to see a huge blue light in my room...
These may be obvious, but the only reason for posting is to get this thread back up :wink:
PostPosted: Thu Jan 27, 2005 9:25 am
I was proud of a small mod I made...
If you have countless swtiches for fans and cold-cathode lights coming out the back of of your box like I did, use (if you have front ports) one of the empty front ports (firewire works well if you're not using it), go to radio-shack and pick up some small slide swtiches and quick-connects (a wonderful 3M product() and mount the smaller switches inside the hole. Gut the wires and strip the and use the quick sonnects to hook them up to the switches! and BINGO, no more unsightly wires hanging out of your case. You can use a dremel to cut small notches in the back if you have multiple wires you need to hide.
 Post subject: 5minute mods.
PostPosted: Sun Feb 27, 2005 6:42 pm
These are nice ideas man. I really don't think i will try the heatsink thing though. I cut out the mesh in the front of my case to increase airflow a week ago. It really did help airflow and ran a test with a simple piece of paper to see if it was able to hold the paper this time around(it did). A quick fix i also did was adding alittle thermal compound (arctic silver) which helped cooling. I recently rearranged all wires to stay out of the way of all airflow and this helped very much so. You can buy rounded cables for ata and cdrom drive hookups. Air flows much easier around round tubbing opposed to ribbon. Another neat idea i had was instead of buying that padding which cuts down on noise. I decided to use some of that egg cartain shaped padding from a package i received. Adds a very nice look and can hide wires underneath. This really also cut down on sound.
PostPosted: Sun Feb 27, 2005 9:44 pm
take a dump on a beach abll and bump it onto ur case.
