It is currently Mon Jan 26, 2015 8:08 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3  Next
 Post subject: 5 minute mods
PostPosted: Tue Nov 23, 2004 2:05 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Some of these might take a little more than 5 minutes but, ohh well.
#1 Easy drive stealthing
This one is free for the most part. Take your plastic (or metal) drive bay cover and spray paint it the color of your choice. An simply tape it with double sided stick tape onto the face of your cd rom drive. How do I open my drive you ask? If you press the cover your drive will usually open, if it dosen't, some dremmeling may be needed.
#2 Better air flow
All as you need for this one is some heavy duty wire cutters for this one. Have you ever noticed the grills built into your case where you put case fans? These probably are some kinda like safety mechanism to keep children from sticking there fingers in the fan (or to save cat whiskers :twisted: ) Well with your cutter simply snip the edges up till it pops off. And if you like, you can smooth the jagged edges with a dremel.
#3 Better cpu temperatures
This will only lower your cpu temperature my 2-3 degrees Fahrenheit, but that is better now isn't it. Take the underside of your heat sink with about 800 grit sandpaper and keep the paper moving in one direction for a few minuets. just to rough it up a little. Then take some polish (i will post a link for the right type soon, or if you have any suggestions) and polish until you get a mirror like finish. This will help heat transfer.
I would post pix if had a working digital camera
:x
PostPosted: Tue Nov 23, 2004 2:09 pm
Monkey Federation (Top 10)*
Good job Gamer. This thread may go somewhere. P.S. Take your pix to Wallyworld and get them on CD.
PostPosted: Tue Nov 23, 2004 2:13 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
I shall never use 35mm again :shock:
PostPosted: Tue Nov 23, 2004 2:16 pm
Easy case window:
You will need: Chainsaw, clear plasic, glue. You can guess what to do.
7yrs+11,000 Posts
7yrs+11,000 Posts
Modding poetry, that could catch on.
willah wrote:
Easy case window:
Chain saw the clear plastic and eat the glue?
PostPosted: Tue Nov 23, 2004 2:17 pm
Your loss!
PostPosted: Tue Nov 23, 2004 2:22 pm
The gluesticks at my old school tasted like vanilla :) They were good.
PostPosted: Tue Nov 23, 2004 2:28 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
:mrgreen:
PostPosted: Tue Nov 23, 2004 11:18 pm
Contributing Writer
Contributing Writer
This thread actually has potential if anyone cares to get it back on track.
PostPosted: Wed Nov 24, 2004 12:02 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
so about these mods........ any1 have any more ideas?
PostPosted: Wed Nov 24, 2004 2:18 pm
Celeron
Celeron
Yes.
Take off the current case badge you've got, get this and stick it where the old case badge was. Bam! 5 minute (1%) case mod. :D
PostPosted: Wed Nov 24, 2004 2:20 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
ok then :roll:
PostPosted: Wed Nov 24, 2004 4:32 pm
Smithfield*
Smithfield*
i do that mod on every new computer i build!
PostPosted: Wed Nov 24, 2004 4:39 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
I wuldent really conisder that a mod. I would consider that a sticker placment.
PostPosted: Wed Nov 24, 2004 5:27 pm
Celeron
Celeron
Well, that would be considered a mod like... 5 years ago. :P
PostPosted: Wed Nov 24, 2004 5:29 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
a new floppy drive was a considerable mod 5 years ago. And it used to be badass yo keep the coverings off your case (although i steel do because i am in there so often)
PostPosted: Wed Nov 24, 2004 7:27 pm
Contributing Writer
Contributing Writer
Don't be a downer, at least he's not hijacking the thread. I don't know that there's going to be a plethora of 5 minute mods, so take what you can get ;)
PostPosted: Thu Nov 25, 2004 3:42 pm
Team Creamsicles
Team Creamsicles
how abt painting things on ur case with washable walmart paint? or adding cool lighting stuff.
PostPosted: Thu Nov 25, 2004 9:34 pm
Celeron
Celeron
Just as cheesy and my sticker mod so yeah.
