It is currently Sat Mar 28, 2015 5:11 am
 Post subject: plastic scratches
PostPosted: Sun Nov 14, 2004 5:59 pm
Smithfield*
Smithfield*
ok i guess this is a good forum to post this in. i bought an ipod skin and theres a plastic piece to cover the screen so it doesnt get scratched. so instead the plastic got all scratched up. now its pretty much unviewable. so what do you guys reccommend for taking out light to medium scratches from plastic. they arent like deep gouges or anything, just enought so that its hard to see unless the light is perfect.
PostPosted: Sun Nov 14, 2004 6:06 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
what? ok so you have scratches in you ipod screen (thats about all i got outta that) the best thing to use is tooth paste.
PostPosted: Sun Nov 14, 2004 6:18 pm
Smithfield*
Smithfield*
not on the screen, theres a plastic piece that came with the cover the protects the screen, that is what gets scratched instead of scratching the screen. tooth paste? how, like buff it in?
PostPosted: Sun Nov 14, 2004 6:56 pm
some metal polishes will work on plastic too, u can try that. takes a lot of rubbing tho.
 Post subject: Re: plastic scratches
PostPosted: Mon Nov 15, 2004 5:57 am
I'd rather be modding!
Don't use tooth paste on clear plastic - it will make it hazy. There are plastic polishes out there. You might try some CD polish and follow it with some future floor polish (modelers do that). Why not just buy a new skin??
Also, in the future, you can buy PDA screen protectors and cut them to fit. They are disposable. That might help.
There was a thread not too long ago in here about the same subject. Maybe you can find it.
Manta
PostPosted: Mon Nov 15, 2004 11:56 am
Team Member/ Ex-Team Member/ Team Member
http://www.lotionsource.com/details/tanning_accessories_supplies/novus_polish_1_plasticcleanandshine.html
Novus is what we use at work for plastic #1 is more a cleaner #2 and #3 work on scratches better. For Acrylic flame polishing works well.
PostPosted: Tue Nov 16, 2004 7:35 am
is the case comprised of two pieces? (case + screen protector) i know mine is and maybe if yours is as well you can pick up a brand new one on ebay.
PostPosted: Tue Nov 16, 2004 1:42 pm
Smithfield*
Smithfield*
yea mine is a cool flexible rubber skin thats blue, and then a little plastic piece that goes under thats the size of the screen. i dont feel like buying another one, the one i have is great, i was just looking for a quick easy fix.
