It is currently Wed May 22, 2013 11:14 am
 Post subject: Putting Good Use to an Old Laptop LCD
PostPosted: Fri Nov 12, 2004 10:21 pm
Hey guys, I am definitely not a modder, but I sure am beginning to become interested with the concenpt. My question for you all is: Is there any way that I can take the LCD out of an old Dell Latitude to use for just about anything? The laptop looks something like this:
Not sure what the exact make and year is, but if that makes a difference I'll definitely look it up. Also, if it is possible, a link to a guide with images would be awesome. Thanks in advance for any responses!
PostPosted: Sat Nov 13, 2004 8:08 am
it would be difficult to do, they are many models of lcd's made so there isn't a standard interface...if you know the model# of the lcd you could find out more(you'll have to take it appart to find the model#)
PostPosted: Tue Nov 16, 2004 3:14 pm
Monkey Federation (Top 10)*
Could you narrow your "just about anything" down a little?
I will automatically assume that you don't want to use it for hammering nails.
PostPosted: Tue Nov 16, 2004 9:37 pm
I mean for displaying just about anything.
PostPosted: Fri Nov 19, 2004 11:20 am
There's actually an article up over on THG about how to make your own projector using an LCD display.
Here's the link if it hasn't been mentioned here yet, pretty spiffy.
http://www6.tomshardware.com/howto/20041113/index.html
PostPosted: Sun Nov 21, 2004 8:20 pm
Team Member*
Team Member*
Or if you can get a hold of one to three more you can make a picture window. I will follow up with the link. :idea:
PostPosted: Sun Dec 05, 2004 12:54 pm
M-Powered
M-Powered
uhm, the THG guide assumes you have an LCD with a VGA/DVI interface... good luck getting that laptop LCD working with a DVI connector.
